Channel Controls — Blocks
The following tables outline the functions, parameters, and settings that can be configured in the OPERA Cloud Interfaces for Channel Controls.
Table 16-26 Channel Controls — Block Settings
| CONTROL NAME | RELATED FUNCTION / PARAMETER / SETTING | DESCRIPTION |
MAXIMUM NO OF ROOMS ALLOWED TO BOOK [MAXIMUMNOOFROOMSALLOWEDTOBOOK] |
Maximum No Of Rooms Allowed To Book by external channel. |
MASTER ALLOCATION BLOCK ID [MASTER_ALLOCATION_BLOCK_ID] |
Master Allocation Block ID to be used when creating a block through OWS. |
MAXIMUM NUMBER OF ROOMS PER BLOCK [MAXIMUM_NUMBER_OF_ROOMS_PER_BLOCK] |
Maximum number of rooms per day that can be allocated when creating a Block/Allotment thorough web. |
MINIMUM NUMBER OF ROOMS PER BLOCK [MINIMUM_NUMBER_OF_ROOMS_PER_BLOCK] |
Minimum number of rooms per day that can be allocated when creating a Block/Allotment thorough web. |
Parent topic: Channel Controls
