Configuring Property Interfaces Unit Charges
Editing Post Unit Charges
From the Administration menu, select Interfaces, and then select Property Interfaces.
Enter search criteria and click Search.
Select the interface, then click the vertical ellipsis and select Edit.
Select the Unit Charges link and then click Edit.
Post unit charge based on. Select a value from the list:
Meter pulse
Total Amount
Auto choose
Click Save.
Adding Property Interface Unit Charges
Select the Unit Charges link and then click New.
Trunk ID. Enter the trunk ID. A trunk can be defined as a set of phone line going out of or coming into the hotel. A single property can have several trunks. For example, one trunk could be strictly used for local calls and another trunk could be strictly used for international calls.
Line Type. Select the line type. The options are:
R1 (Line 1)
R2 (Line 2)
B (Booth)
H (House)
VIP code. Select the VIP code.
Default Charge. Enter the default charge. When a call is made, OPERA Cloud looks at all defined variables/parameters to try and identify the call and assign a unit charge. If OPERA Cloud is unable to identify the call based on the variables/parameters defined in the system, OPERA Cloud identifies the call as a House call and the value entered in this field is used as the default charge.
Tariff. Enter the tariff number. The tariff number allows you to charge a different monetary value for each line type. For example, tariff 1 may be for line 1 and tariff 2 may be for a house line.
Click Save.
Editing Property Interface Unit Charges
When editing existing unit charges, charges with an identical trunk ID/line type/VIP code/tariff combinations are grouped together.-
Enter the search criteria and click Search.
Select the Unit Charges link.
Select the charge unit then click the vertical ellipsis and select Edit.
Update details.
Click Save.
Deleting Property Interface Unit Charges
Select the interface, then click vertical ellipsis and click Edit.
Select the charge unit then click the vertical ellipsis and select Delete.
Click Delete to confirm.
Parent topic: Configuring Property Interface
