Configuring Block Wash Schedules
Adding a Block Wash Schedule
From the Administration menu, select Block Management, and then select Wash Schedule.
Click New and complete the following fields:
Code. Enter a code to identify the Block Wash Schedule.
Description. Enter the text that describes the Block Wash Schedule.
In the Schedule Details panel, click New and complete the following fields:
Days prior to arrival. Enter the number of days prior to arrival to determine when the system performs the wash.
Wash by number of rooms. Select to determine the number of rooms to return to house inventory based on occupancy levels and enter the occupancy levels.
Wash by %. Select to determine the percentage of rooms to return to house inventory and enter the percentage.
Click Save.
Editing a Block Wash Schedule
Select or confirm the Property.
Enter search criteria and click Search.
In the search results, select the code and click the vertical ellipsis.
Click Edit.
Update the configuration and click Save.
Deleting a Block Wash Schedule
Click Delete.
Parent topic: Block Wash Schedules
