Channel Controls — Blocks
The following tables outline the functions, parameters, and settings that can be configured in the OPERA Cloud Interfaces for Channel Controls.
Table 16-5 Channel Controls — Block Settings
| CONTROL NAME | RELATED FUNCTION / PARAMETER / SETTING | DESCRIPTION |
| MAXIMUM NO OF ROOMS ALLOWED TO BOOK [MAXIMUMNOOFROOMSALLOWEDTOBOOK] | Maximum No Of Rooms Allowed To Book by external channel. | |
| MASTER ALLOCATION BLOCK ID [MASTER_ALLOCATION_BLOCK_ID] | Master Allocation Block ID to be used when creating a block through OWS. | |
| MAXIMUM NUMBER OF ROOMS PER BLOCK [MAXIMUM_NUMBER_OF_ROOMS_PER_BLOCK] | Maximum number of rooms per day that can be allocated when creating a Block/Allotment thorough web. | |
| MINIMUM NUMBER OF ROOMS PER BLOCK[MINIMUM_NUMBER_OF_ROOMS_PER_BLOCK] | Minimum number of rooms per day that can be allocated when creating a Block/Allotment thorough web. |
Parent topic: Channel Controls
