Configuring Cashiers
Cashier setup enables you to define and manage cashier IDs for your property’s cashiers. A cashier ID is used to track each posting made to a reservation or AR account. The details are available on financial reports and cashier closure reports.
You must configure cashier IDs for the Night Audit Cashier Id and Income Audit Cashier Id settings in OPERA Controls (see OPERA Controls — End of Day for more information). Cashiers must also be configured for each integrated system that posts charges to OPERA Cloud. For example, Point of Sale, Video, Minibar, PBX / Call Accounting, and Leisure: Spa / Golf .
Adding a Cashier
From the Administration menu, select Financial, select Cashiering Management, then select Cashiers.
Click New and complete the fields and options on the Manage Cashier screen.
Cashier ID: Enter a number to identify the cashier ID.
999999 is the highest number you can assign to a cashier.
Name: Enter the cashier's name. This could be the name of a person, the name of a shift, or other descriptive term to associate with this cashier ID.
Starting Amount. Enter the local currency starting balance assigned to the cash drawer for employees signing on with this cashier ID.
If you choose to work with fixed starting balances, enter the opening amount of each cashier's float (or bank) in this field. This is the amount the employee retains in the cash drawer and carries forward to the next day. If your policy requires cashiers to completely empty their cash drawer each night and deposit all the money in their banks into the safe, then your property is working without fixed starting balances and no entry is required. The starting amount is reflected on the Cashier Closure Report.
Maximum Daily Uses: Enter the number of times cashiers can close and re-open their cashier in one business day.
At the end of each shift, the cashier is balanced and closed. After closing, you must re-open before you can post another transaction. You can set the maximum daily user from 0 to 9999 (unlimited). For security purposes, you might want to restrict users to one or two uses per business day. Enter the number 1 here if you do not want a cashier reopened after it has been closed.
Float Over/Short: Select if the cashier is able to drop above or below the required drop amount.
OPERA Cloud maintains a running total of any differences that might occur between the cash amount posted by the cashier and the cash amount the cashier actually entered during cashier closing. OPERA Cloud adds or subtracts the difference (depending on whether the cash amount is over or short) and updates the total accordingly.
Cashier: Select to configure this cashier ID for a standard user cashier. This is the default.
LDAP Template: Select to use this cashier ID as a template. This template is then used for automatically creating and assigning cashier IDs, to users granted the <ORG>_OPERACASHIER role, The cashier IDs created for users inherits the attributes set on this template Cashier (e.g., _Starting Amount, Maximum Daily Uses, etc.). The Cashier Name is taken from the login User Name and a Cashier ID number is assigned by OPERA Cloud . Only one LDAP Template cashier ID can be created.
Interface Cashier: Select if the cashier ID is reserved for use by interfaces.
Kiosk Cashier: Select the check box if this cashier ID is reserved for use by Kiosk applications. This cashier ID is not available for selection from the Cashier ID list of values on the Cashier Login screen. Only one Kiosk Cashier can be created and it cannot be selected as LDAP Template. This option is enabled when the OPP_KSK integration service is active.
Click Save.
Editing a Cashier
Enter search criteria and click Search.
Click the row level vertical ellipsis Actions menu for the cashier and select Edit.
Make the desired changes.
Inactive. Select to set the cashier inactive.
If a Cashier ID is attached to a user or a control setting, you cannot make the cashier inactive. (A message alerts you that dependencies exist.)
Click Save.
Parent topic: Configuring Cashiering Components
