Modify/Update Block — Shift Block Date
Prerequisites for Shift Block
With the Shift Block OPERA Control active, you can update a block and associated catering events to a new arrival/start date. When a shift date is initiated, the room allocation and all events associated with the block are updated. To ensure that the date change does not create availability conflicts, OPERA Cloud checks to ensure that room type inventory, function spaces, and event resources are available on the new dates.
When the Event Waitlist OPERA Control is active, and the status change/shift dates would result in a wait-list situation, a processing screen appears with the option to wait-list or cancel the event. When the Event Waitlist OPERA Control is not active, and status change/shift dates would cause an over book situation (with another block/event), a processing screen appears with the appropriate message, and you must cancel the current action.
Other dates (Cutoff Date, Follow-up Date, Decision Date, Shoulder Dates, Catering Follow-Up Date, Catering Decision Date, and Rooming List Due Date) are automatically updated by the same number of days that the block dates have shifted.
Shift Block and Event Start Date
  1. From the OPERA Cloud menu, select Blocks, and select Manage Block.
  2. Enter search criteria and click Search.
  3. Select a block in the search results, click I Want To . . . , and select Shift Block Date.
  4. Enter or select a new start date for the business block.
  5. Click Save.
Related Topics
