Configuring Credit Card Terminals (PIN Entry Payment Devices)
Adding Credit Card Terminals
From the Administration menu, select Interfaces, select Interface Devices, and then select Credit Card Terminals.
Click New and enter the following details:
Property: Enter or select the property
Terminal ID: Enter the terminal ID number provided by the vendor.
Terminal Label: Enter a label or name for the device that identifies its physical location.
Device Area: Link the device to an area. Refer to Configuring Device Areas.
Click Save.
Editing Credit Card Terminals
Enter search criteria and click Search.
Select the device, then click the vertical ellipsis and select Edit.
Update configuration.
Click Save.
Deleting Credit Card Terminals
Select the device, then click the vertical ellipsis and select Delete.
Click Delete to confirm.
