Managing Block Notes
Adding Block Notes
  1. From the OPERA Cloud menu, select Bookings , Blocks , and then Manage Block.
  2. Enter search criteria, click Search.
  3. Select Block in search result, click I Want to. . ., Notes or click the Notes link in Block Presentation.
  4. Click New.
    1. Type: Select a note type from the list. For more information, see Configuring Note Types.
    2. Internal: Select this check box if the note is to be treated as internal.
      Internal notes are not output on stationery or on reports unless the report explicitly allows display of Internal Notes. You can deselect this check box when Override Internal is selected in the note type configuration.
    3. Title: Enter a summary title for the note. Defaults according to the note type.
    4. Comment: Enter or paste the note details; a maximum of 2000 characters are permitted.
  5. Click Save.
Viewing and Updating Block Notes
  3. Select the Block in the search result, click I Want to..., Notes or click the Notes link in Block Presentation.
  4. Select the note, click ± to expand the card to read the note comments.
  5. Click the vertical ellipsis Actions menu and click Edit.
  6. Update details.
  7. Click Save.
Deleting Block Notes
  4. Click the vertical ellipsis Actions menu and click Delete.
  5. Click Delete to confirm.
