Managing Blocks Traces
Adding a Trace
From the OPERA Cloud menu, select Bookings, select Blocks, and then select Manage Block.
Enter search criteria and click Search.
Select the block in the search result, click I Want To..., Traces or click the Traces link in Block Presentation.
Click New and complete the following:
Department. Select the department(s) for trace.
From Date: Enter a From date.
To Date: Enter a To date.
Time: Enter time.
Trace text: Enter the trace text.
Quick Insert: Click to select from pre-configured trace text for the selected department. Configuring Trace Texts.
Click Save.
Updating a Trace
Only open traces are displayed by default, to view completed traces click Vertical Ellipsis, Show Completed.-
Enter block criteria, click Search.
Click + to expand the card and view trace details.
Click and select Edit.
Update details.
Click Save.
Resolving / Completing Trace
the vertical ellipsis Actions menu-
Enter search criteria, click Search.
Click the vertical ellipsis Actions menu and select Complete.
Deleting a Trace
Click the vertical ellipsis Actions menu, and select Delete.
Click Delete to confirm.
Parent topic: Blocks
