Validating Membership Numbers using an Integrated Solution
Membership numbers can be validated in a CRM / loyalty solution integrated with OPERA Cloud, using a REST web service call. The membership number validation API accepts JSON responses from the integrated system.
Setup Requirements
Configure an Configuring Outbound Systems for the integrated CRM.
Configure an External Database for the CRM and select the Outbound System configured.
Update the Membership Type:
Update Card Details, set Validation to External.
Update Membership Handling, select the External Database.
REST Request
The following URL is posted to the service path of the integrated system.
Path Parameters:
externalSystemCode: The external system to which the REST request is sent.
chainCode: The OPERA Cloud tenant/chain code.
Query Parameters:
membershipType: The membership type
membershipNo: The membership number to be validated.
hotelID: The ID at which this membership is being created.
Example: https://<externalsystem:port>/v1/externalSystems/{externalSystemCode}/chains/{chainCode}/validateMembershipNumber?membershipNo=87876&membershipType=XYZ&hotelId=PROP1
Table 15-4 Sample JSON Response
Successful |
Unsuccessful |
Parent topic: Guest Loyalty Programs
