Swapping or Shifting Assigned Rooms (Video Transcript)
In this video, you will learn how to swap or shift the assigned rooms between two reservations
0:05
with matching arrival dates and room types.
0:07
If one of the rooms is marked Do Not Move or the rooms are not available for the entire
0:12
stay date range of the other reservations,
0:15
then swapping/shifting is not allowed.
0:17
Rooms can only be swapped or shifted before check-in.
0:20
Let's get started!
0:22
To swap assigned rooms, in the OPERA cloud menu, select Front Desk,
0:27
Front Desk Workspace, and then Room Assignment.
0:31
When using the room assignment window to Swap, Shift, or use the Swap/Shift button, you must
0:36
click the modify search criteria link,
0:38
and leave the Room Assignment filter empty.
0:41
Or in the OPERA Cloud menu, select Front Desk, then select, Arrivals.
0:48
Click Search.
0:49
In the search results, I can select any two reservations of the same type.
0:53
Next, click Swap Rooms.
0:55
Then confirm, and click OK.
0:58
The rooms have swapped.
0:59
To shift the assigned room to another reservation, Select Front Desk, Front Desk Workspace, and
1:06
then Room Assignment,
1:07
or select Front Desk, and then Arrivals.
1:11
Click Search.
1:13
In the search results, Select a reservation with a room assigned, then select one reservation
1:18
without an assigned room.
1:21
Click the Shift Rooms.
1:23
Then confirm, then click OK.
1:27
The rooms have shifted.
1:29
To ensure which reservations you can swap or shift, you can access the Swap/Shift Rooms
1:34
screen.
1:35
To use the Swap/Shift Rooms screen, Select Front Desk, Front Desk Workspace, and then
1:41
Room Assignment,or select Front Desk,
1:45
and then Arrivals.
1:46
Click Search.
1:48
Select a single reservation either assigned or unassigned based on your choice to swap
1:52
or shift.
1:53
Next, click Swap/Shift Rooms.
1:56
Enter the search criteria on the Swap/Shift Rooms page and click Search.
2:01
The Swap/Shift Rooms screen displays the Profile and Reservation details of the source reservation.
2:06
In this example Click Swap Rooms, based on the criteria that was previously entered.
2:11
The confirmation window appears.
2:13
click OK.
2:14
2:16
The Swap/Shift Rooms link is also available from the Assign Room or Room Details screen.
2:22
Select Front Desk, Front Desk Workspace, and then select Room Assignment.
2:27
Or select Front Desk, then select Arrivals.
2:30
Click Search.
2:32
Then locate the reservation in the search results and click the Assign Room link.
2:36
Or, locate the reservation in the search results, click the I Want To icon and then click, Assign
2:43
Room.
2:45
The Assign Room window appears and you are able to click the Swap/Shift rooms link to
2:49
start the process.
