Using OPERA Cloud Reports (Video Transcript)
00:06
In this video, you will learn how to generate reports in OPERA Cloud.
00:10
Let's get started.
00:11
Go to reports, and then select manage reports.
00:14
I can search for a report by report name or I can select a report group from the drop-down
00:19
list to view a list of reports for the report group.
00:23
The report groups available depend on the report group tasks assigned to your user's
00:27
role.
00:28
In this example, to see a list of all reports, I select all report groups and then click
00:33
search.
00:34
I can generate a report with the default parameters or I can choose to edit the report parameters
00:39
before generating the report.
00:42
In this example, I select the option to edit the report parameters to change the default
00:47
report parameters for the reservation forecast report.
00:50
Now, I can select a date range and change any of the other report parameters.
00:54
I can choose to select a specific rate code for this report from the drop-down list, or
00:59
as in this example, I select all rate codes.
01:02
Next, I can select the option to generate the report, I can download, email, or preview
01:08
the report.
01:09
I can download the report in any of the following formats: HTML, RTF, PDF, XML, Delimited, Delimited
01:18
Data, and Excel which can be used for BI Publisher-based reports.
01:22
Or I can email to one or more recipients by using a comma between email addresses.
01:27
In this example, I select to preview the report as a PDF, and then I can print the report
01:32
to a local or network printer.
01:34
Now, I see the reservation forecast PDF report.
01:37
I can download or print the report directly from the browser.
01:40
Let's take a look at another report.
01:42
Now, I select the AR Activity report from the reports list.
01:46
And then click the edit report parameters option.
01:48
I can change any of the AR activity report parameters.
01:52
And then I click to preview the AR Activity report.
01:54
Now, I can view the AR Activity report.
