Configuring UDF Values
Configure the list of values to appear for a specific UDF Group.
For example, you might have a Vehicle Type flex field on profiles containing the values GM, Ford, BMW, Mercedes, Honda, and so on. These values would then be linked to the Vehicle Type UDF Group.
Adding a UDF Value
From the Administration menu, select Enterprise, select User Interface Management, and then select UDF Values.
Click New and complete the following information:
Group: Select the UDF group from the list. For more information, see Configuring UDF Groups.
Code: Enter the code for the user defined value.
Description: Enter a description for the user defined value.
Click Save or click Save and Continue to add another.
Editing a UDF Value
- Enter search criteria and click Search.
From search results, select the UDF value then click the vertical ellipsis Actions menu and select Edit.
Update the details.
Click Save.
Deleting a UDF Value
From search results, select the UDF value then click the vertical ellipsis Actions menu and select Delete.
Click Delete to confirm.
Parent topic: UDF Groups and Values
