Deleting Page Composer Customization
Prerequisites for Deleting Page Composer Customization
The Delete Customization feature enables you to delete Page Composer customization and personalization changes made by users at the Chain, Hub, or Property levels.
When a page panel is customized or personalized a custom file is created for storing the changes. Multiple changes made to the same area are stored within the custom file and deleting this file deletes all customization or personalization changes.
The Delete Customization screen provides the option to delete these files from a central location, thereby, enhancing the existing Delete Customization option in panels where customization is available.
The search results on the Delete Customization screen show the custom file name, user, updated date, and screen where the customization and/or personalization was made.
Deleting Customizations
  1. From the Administration menu, select Enterprise, select User Interface Management, and then select Manage Customizations.
  2. In the Search fields, select a Customization Layer (Chain, Hub, Property, or User) and optionally enter a Customization Area, then click Search.
    1. Chain: Allows deletion of Chain-level customization. Delete Chain Customization is only available for users assigned Delete Customization for Chains tasks through a chain role.
    2. Hub: (Only available for users logged in at Hub level). A user logged in at the Hub level may delete customization at the logged in Hub.
    3. Property: A user logged in at the Hub level may select a property to delete property-level customization. A user logged in at the Property level can only delete customization for the property currently logged in at.
    4. User: A user with the Delete Users Personalization task may delete personalization for self and personalization for other users. A user with the Delete Personalization task can only delete his or her own personalization.
  3. The search results area provides columns for Path, Screen, File Name, User, and Updated Date.
    1. Path: Shows the breadcrumbs path where customization or personalization was made.
    2. Screen: The screen or area where the customization or personalization was made.
    3. File Name: Shows the internal file name for the customized or personalized area.
    4. User: The name of the user who last made a change to the listed area.
    5. Updated Date: The date and time when the last change was made to the listed area.
  4. Select the customization file(s) you want to delete and click Delete.
  5. Click Delete again to confirm the deletion.
