Creating Master and Sub Blocks
Creating a Master Block
Master blocks are indicated by this icon: This icon depicts a master block.
  1. From the OPERA Cloud menu, select Bookings, select Blocks, and then select Manage Block.
  2. Click I Want To . . .and select (Create) Master Block.
  3. Complete the details for the master block. For more information, see: Creating a Block
  4. After saving the master block, an initial sub block is auto-created.
  5. Click Save or click Save and Go to Presentation to view the Master Block. For more information, see: Managing Blocks
  6. Select the Master/Sub Block tab in Block Presentation to view the sub block.
  7. You can now allocate rooms and set up catering events.
Creating a Sub Block
Sub blocks are indicated by this icon: This icon depicts a sub block
  2. Enter search criteria for the master block and click Search.
  3. Select the master block in the search result, click I Want To . . . , and select (Create) Sub Block.
  4. On the sub block page, enter the following details:
    1. Property. Enter or select the property.
    2. Block Name. Enter the name of the sub-block.
    3. Start Date. Enter the sub block start (arrival) date.
    4. Night. Enter the number of nights.
    5. End Date. Enter the sub block end (departure) date.
    6. Block Code. Enter a block code. Click Get Default Block Code to generate a block code.
  5. Click Save or click Save and Go to Presentation to view the sub block.
