Interface Resync - Products
This synch is only available from ORS to OPERA Cloud PMS.
  1. From the OPERA Cloud Exchange menu, select Interface Resync, and then select Products, from the drop down list.
  2. The Type and Property values are taken by default. Search and select an Interface that is to be resynced.
  3. In the Products to Resynchronize panel, select From Start Date and To Start Date for the resync.
  4. Select Products. This option is to find only Packages that are not linked to groups. This option is usually the most desired for Resync choice and is the default upon entering this screen.
  5. Select Groups. This option is to find only Packages that are linked to groups.
  6. Search and select the Product Codes.
  7. Click Resync or Resync History.
