Custom Headers
Custom Headers configuration is provided for defining the additional custom header names and values for the Outbound Codes created.
Custom Headers allow you to define a maximum of five custom header names and values that can be communicated with external systems during API calls.
Custom Headers configuration is available under the I Want To . . . options.
  1. Search for the Outbound Code created at the Global (Chain) or Property Level.
  2. Click the I Want To . . . icon from the search results row where you want to define Custom Headers.
  3. The Custom Headers screen launches in a pop-up window.
  4. Click Edit to define the Header Name and Header Value and then click Save.
  5. You can Edit and modify values for any changes or you can set the blank field to Delete and then click Save to update the configuration.
