Copying Conversion Codes
Copying is an efficient way to populate the interface conversion
codes, instead of manually inserting the codes one by one. Copy Conversion
Codes helps you to copy the conversion codes from OPERA Cloud to the
selected interface. Copy option also validates new and active/inactive
OPERA Cloud codes. It copies these codes to the Interface Mapping
conversions along with their respective groups. An example of an extensive
list of conversion codes can be the Countries or Rate Codes. This
form copies the conversion codes from OPERA Cloud based on the activated
conversion codes for this interface. When copying, OPERA Cloud and
external system values are populated with the same value in the conversion
details.
- From the Exchange menu, select Interface Setup and then select Copy Conversion Codes.
- Enter search criteria, then click Search.
- Click to select one or more conversion codes in the search result. Click Select All to select all.
- Click Copy.
Parent topic: Interface Setup
