Using Quick Check-Out
Quick Check Out is a fast way to check out reservations when the payment method is credit card or direct bill or the reservation has a zero balance.
Make sure the guest's credit card has sufficient authorization to cover the balance.
Make sure Direct Bill AR accounts are not restricted and have not exceeded credit limits.
Make sure cash guest folios have a zero balance.
Mass Check Out Reservations
Mass check out steps you through the settlement and checkout of each reservation
From the OPERA Cloud menu, select Front Desk , select Front Desk Workspace, and then select Quick Check Out.
Enter search criteria then click Search.
Select the Table or List view
Select multiple reservations in the search result then click Mass Check Out.
Folio Settlement appears for the first reservation
Enter payment details
Click Settle and Send Folio.
Report Destination
Select a Folio Style.
Select a Report Destination.
Click Process.
Click Check Out Now to check out the reservation or click Schedule Check Out to schedule the check out for a later time. For more information, see Scheduling a Checkout.
Select a room status.
Click Save.
Repeat step 5 for the next reservation.
Auto (Settlement) Check Out Reservations
Auto checkout processes credit card or direct bill settlements and checks out the reservation automatically. The room status is updated according to the Room Status for Zero Balance and Auto Checkouts OPERA Control. A status panel will display the progress for each reservation.
Select the Table or List view.
Select multiple reservations in the search result then click Auto Check Out.
Check Out All Zero Balance Due Out Reservations
Use this option to check out all due reservations with a zero balance. The room status gets updated according to the Room Status for Zero Balance and Auto Checkouts OPERA Control.
Click Check Out Zero Balance Departures.
A status screen displays the progress.
For all reservations that were checked out successfully, Successfully Processed is displayed.
For any reservation that is not checked out successfully, a message indicating the reason is displayed.
The following are scenarios and their expected outcome when using the Check Out Zero Balance Departures.
Table 4-4 Scenarios and expected outcome
# | Reservation Status | Scenario | Outcome |
1 |
Day Use |
Reservation has zero rate and Zero Reservation Balance * Windows has no postings |
Checked Out Successfully |
2 |
Day Use |
Reservation has zero rate and Zero Reservation Balance * Windows has postings but settled and no folio generated |
Checked Out Successfully and Folio Generated |
3 |
Day Use |
Reservation has zero rate and Zero Reservation Balance * Windows have charges/payments and at least one or more windows balance is non zero |
Error Shown "Reservation has a balance, checkout cannot be processed" |
4 |
Day Use |
Reservation has Non Zero Rate and Zero Guest Balance * Windows has no postings |
Charged are posted Error Shown "Reservation has a balance, checkout cannot be processed" |
5 |
Day Use |
Reservation has Non Zero Rate and Zero Reservation Balance * Windows has postings but settled and no folio generated |
6 |
Day Use |
Reservation has Non Zero Rate and Zero Reservation Balance * Windows have charges/payments and at least one or more windows balance is non zero |
7 |
Due Out |
8 |
Due Out |
9 |
Due Out |
Reservation has Non Zero Rate, zero reservation balance and payment method configured is Direct Bill. But the payee does not have AR number configured. Payment is posted against the charges using different payment method and folio is not generated. |
Error Shown "AR Acocunt does not Exist" |
10 |
Due Out |
If Folio requires Fiscal Printing |
Error Shown " The Folio requires the Fiscal Printing, please process the checkout manually." |
Related Topics
Parent topic: Departures and Checkout
