Custom Headers
Use Custom Headers configuration to define additional custom header names and values for an Outbound System. You can define a maximum of five custom header names and values that are to be included in the API calls to the external system.
Editing Custom Headers
From the Toolbox menu, select System Setup, and then select Outbound System Configuration.
Enter search criteria, then click Search.
Select the outbound system in the search result, then click I Want To . . . and select Data Value Mapping.
Header Name: Enter a header name.
Header Value: Enter a header value.
Click Save.
Parent topic: Configuring Outbound Systems
