Block Defaults for OXI
Table 30-2 Block Defaults for OXI
| Block Defaults | Description |
| Block Rate Code | Select a rate code that has all of the configured room types
for the property.  Since rates can be subject to restrictions
that either close the rate and or room types depending on hotel occupancy,
we strongly suggest making a ‘OXI Default’ group rate code and insert
this value.
| Block Status | OXI shows only the deductible block status types in this list of values as all received blocks from external systems are automatically considered deductible. This is a crucial element for the creation of a block and has to be set. |
| Block Owner | This is no longer mandatory but depending on the OPERA Cloud function Generic > Owner. If this is indicated, a block owner must be set in order to update the block in OPERA Cloud. |
| Destination Code | When processing a Canceled, Lost or Turndown message the destination
code can be matched to the code used as the default in the OXI Block
Defaults tab. If no match is found then the OXI default, if defined,
can be applied.
Parent topic: Block Parameters and Settings
