Viewing Interface Controller Registry
You can view the registry settings of the IFC Controllers. These details are updated every time the IFC Controller is restarted on the selected machine.
Viewing Controller Registry
From the Administration menu, select Machines, select Interface Logs then select Controller Registry.
Enter search criteria then click Search.
Parent topic: Interfaces Administration
