Copying Conversion Codes
Copying conversion codes is an efficient way to populate
the interface conversion codes, instead of manually inputting the
codes one by one. An example of an extensive list of conversion codes
would be the Countries or Rate Codes. When copying, OPERA Cloud and
External System values are populated with the same value in the conversion
details.
Copying Interface Mappings
- From the Exchange menu, select Interface Setup and then select Copy Conversion Codes.
- Enter search criteria, then click Search.
- Click to select one or more conversion codes in the search result or click Select All.
- Click Copy.
Related Topics
Parent topic: Interface Setup
