Interface Resync - Stay
Stay files can be created for some interfaces after the guest
has checked out and the OPERA Cloud night audit has run.
- From the OPERA Cloud Exchange menu, select Interface Resync, and then select Stay, from the drop down list.
- The Type and Property values are taken by default. Search and select an Interface that is to be resynced.
- In Stay to Resychronize panel, enter a From Departure Date. Select the first restriction start date for the resync. Enter To Departure Date. Select the last restriction start date for the resync.
- Enter the First Name, type the specific first name of guest whose stay data shall be resynced. Enter the Last Name, type the specific last name of guest whose stay data will be resynced.
- Click Resync or Resync History.
Parent topic: Interface Resync
