Charging Purchases Using Post It
When the Pre Stay Charges OPERA Control active, Post It does not support room charge to future reservations enabled with pre-stay charging. For more information, see Managing Reservation Payment Instructions
When the Check In Prepay Rules OPERA Control is set to Auto Advanced Bill Posting, you cannot settle charges by room charge to a reservation account.
When the Transaction Discount OPERA Control is active, charges may be automatically discounted for specific members. For more information, see About Membership Auto Discounting.
When the Allow Negative Postings (Charges) OPERA Control is inactive you cannot post negative charges to reservation accounts; overriding the Post Negative Amounts task assigned to your role(s).
When the Credit Card Wallet OPERA Control is set to Profile, a Store Credit Card Token to the Wallet check box is available to save new credit card details in a wallet. A Select a Credit Card action is available to retrieve the credit card details in the wallet.
Posting Charges using Post it
From the OPERA Cloud menu, select Financials, select Cashiering, and then select Post It.
Select Article to post an article.
Select an article or a transaction code for posting. Alternatively, if the item has a UPC number, you can enter value in the UPC field using a UPC scanner or by manually typing it.
Select Transaction Code to post a transaction code
Transaction Code/Description: Enter a transaction code or partial description to filter the transaction codes displayed. All transaction codes configured with the Manual Post check box selected are available.
Select a transaction code to add to the cart.
The selected charge (and generated charges such as tax) appear in the cart. Update the Price as needed.
To remove a charge, select the [x] next to a charge in the cart.
Repeat the steps to post additional charges to the cart.
Covers: Enter the number the covers (Available when the Post Covers OPERA Control is active and the Post Covers task is granted).
To post negative items, first select the Activate Minus Posting button and then select the article(s) being adjusted. Your user role must be granted Post a Negative Post It Article task.
To settle the cart, click Pay.
If settling the cart balance to a room reservation, click the Charge to Room check box. Your role must be granted Charge to Room task to settle the balance to a room reservation account.
Enter a room or guest name then click Search.
To include open folio reservations click the Open Folio check box.
Select the required reservation from search results.
If settling to a credit card, select the payment method, and enter card number, expiration date, and card holder name (swipe or tap card if payment integration is active at property).
A Card Presentcheck box is available when the Payment Services Directive OPERA Control is active. This check box is deselected by default and remains deselected if you manually enter a credit card number. A Credit Card Was Entered Manually message appears when you manually enter a credit card. This check box is automatically selected if you insert or swipe a credit card in a credit card terminal. -
Passer by: You can also search and select a profile and enter reference text to generate a personalized folio.
Click Complete Sale to post the settlement.
Posting Charges using Fast Post
The Code field will retain the selected charge code - repeat entry of Name/Room and Amount to a post new charge.-
Select the Fast Post check box.
Room / Name: Enter or select the room reservation the charge is to be posted to. Select the reservation from the search result.
Code: Enter or select the transaction code to be posted.
Amount. Enter the amount of the charge.
Click Post.
Parent topic: Cashiering and Finance
