Property Interface Control
Prerequisites for Property Interface Control
Property Interface Control allows you to manage the status of features
for the property systems integrated with OPERA Cloud. Quite often
these systems are related to guest rooms and reservations, and may
also apply to other areas in your property.
The Reservation Status search field lists Checked In, In House and Departure status reservations for all IFC types except a Door Lock System (DLS). For a Door Lock System the Reservation Status search field lists future-date arrivals, Due In, Checked In, Inhouse and Departure statuses. You can also select to search for Advanced Check-In reservations when the Advanced Check In OPERA Control is active.The types of integrated systems listed in Property Interface Control include:
                     PBX, Call Accounting, Voicemail and other telephone related systems
                     Room key / Door lock
                     In-room movie / entertainment
                     Minibar
                     WIFI/Internet
                     Building /Energy Management
Related Topics
Parent topic: Miscellaneous
