Using Track It (Video Transcript)
00:06
In this video, you will learn how to use Track It.  In this example, I will set up a task request for
00:11
the delivery of luggage to an arriving guest's  room and then action the request on the OPERA
00:16
cloud mobile application. Let's get started.  To set up a Track It request in OPERA cloud
00:22
go to miscellaneous and then select Track It. Track It manages the storage and delivery of
00:28
guest baggage, parcels, vehicles, and valet parking,  and lost items. Click new. Next I select baggage.
00:38
Now I can enter a ticket number. In this example,  the ticket number will be the luggage tag number
00:42
on the bags that are delivered to the guest. I  click the type magnifying glass and select luggage
00:48
from the list. I can now click select. I click the  action magnifying glass and select deliver to room.
00:55
Then click select. To change the number of bags. I  click the plus sign to increase the quantity to 2.
01:02
I click the location magnifying glass and  select bell desk storeroom to specify the
01:07
current location of the luggage, then click select.  Next, I enter the description, black suitcase.
01:14
To link this Track It request to the guests  reservation I click the name magnifying glass.
01:21
Now I can search for the arrival reservation by  entering a variety of options. In this example,
01:27
I enter the room number and click search. Next  I click the reservation and click select. Now
01:32
I can see the reservation linked to this new  Track It request just created, then click save.
01:38
To find the Track It request I just created,  with the open checkbox selected, I click search.
01:44
Now I can see the Track It request I just created.  I can click the vertical ellipsis to edit, delete,
01:50
or view the history of this Track It request. Now  on a mobile device, I will demonstrate how to view,
01:55
assign, and close this Track It request, once the  bags are delivered to the guest. Go to the OPERA
02:01
cloud mobile application and tap Track It requests.  In this example, I tap baggage. From the drop-down
02:10
list. I select unassigned requests. Next I tap the  Track It request from the list and then tap claim.
02:18
Now I select my requests from the drop-down  list. Then, after the suitcases are delivered
02:23
to the guest I can select delivered item  completed from the action drop-down list.
