Configuring Shift Drop Locations
Adding Shift Drop Locations
You can configure shift drop locations for cashier shift closures. On the Cashier Closure screen, the shift drop locations you configure are associated with the cashier shift closure numbers.
  1. Select the Administration menu, select Financial, select Cashiering Management, and then select Shift Drop Locations.
    When the Multi Property OPERA Control is active, new Shift Drop Locations codes are created by selecting the Template tab. Once created, you can copy Shift Drop Locations codes to specific properties using the Copy action. Refer to Copying Configuration Codes to Multiple Properties for more information.
    Click New and complete the following fields:
    1. Code. Enter a code for the Shift Drop Location.
    2. Description. Enter a description for the Shift Drop Location.
    3. Manage Translation: Click link to configure localized descriptions. For more information, see Configuring Localized Code Descriptions. (Available when the Multi Language OPERA Control is active.).
    4. Sequence. Enter a number that controls the position of this code in lists. Codes without a sequence number assigned are listed in alphabetical order following codes with a sequence assigned.
  2. Click Save to save and close or click Save and Continue if you want to configure additional shift drop locations.
Editing Shift Drop Locations
  2. Enter search criteria and click Search.
  3. Select the shift drop location then click vertical ellipsis Actions menu and select Edit.
    1. Make the required changes.
    2. Inactive: Select check box to make the shift drop location inactive; inactive codes are not available for selection.
  4. Click Save.
Deleting Shift Drop Locations
  3. Select the shift drop location then click vertical ellipsis Actions menu and select Delete.
  4. Click Delete and confirm.
