Responsys Property Exports
The General export, RESPONSYS_PROP_DAY, exports property details to the Oracle Responsys System. The Oracle Responsys System requires the Responsys Property Export on a monthly basis per Responsys services.
The export captures property details such as Code, Brand, Type, Address, No. of Guest Rooms, No. of Meeting Rooms, Attraction, Airport, Transportation, Alternate, Cities Nearby, and Region for all properties within the chain. You can generate the export for a date or date range.
The OPERA Cloud add on OPP_EXP subscription must be activated for General Exports functionality. The Export is available from the OPERA Cloud menu by selecting Miscellaneous, then Export, then General, and then RESPONSYS_PROP_DAY.
The export contains information on Properties, such as their Brand, Level, Address, Amenities, Attractions, Alternates, Transportation, Features, and so on.
The export contains information on Properties, such as their Brand, Level, Address, Amenities, Attractions, Alternates, Transportation, Features, and so on. There are three export file types available in the list of templates within the General Exports. You can select the applicable export(s) from the Template list (Miscellaneous > Exports > General > New) and add to them your property.
  • RESPONSYS_PROP_DAY. You can run this export manually for a Day or Date Range.
  • RESPONSYS_PROP. You can configure this export to run during End of Day.
  • RESPONSYS_PROP_AUTO. You can schedule this export from Export Schedules.
    The image show the Search and Select Template screen.
Generating the Responsys_Prop_Day Export
You can generate the Responsys_Prop_Day export manually. When doing so, you must select date ranges such as Date, Month, and Year that the report is to cover. The date range is defaulted to the current month (a business date-30 days). For example, if you export the file on May 15, the default date range would be To Date – 15 April and For Date – 15 May. Records for April 15th through May 15th will be generated provided the current business date is later than May 15.
Generating the Responsys_Prop Export
You can schedule the Responsys_Prop export to run during End of Day (EOD). The export frequency is set to Monthly (30 days) by default. When the Night Audit Export check box is selected for the export, the export runs during the End of Day. Once this export is added to the Property, the EOD automatically considers the export based on the export frequency defined. The check box is enabled by default, and you can deselect the check box if you decide against running the export during EOD.
Generating the Responsys_Prop_Auto Export
You can schedule the Responsys_Prop_Auto export from the OPERA Cloud Export Scheduler.
  1. From the OPERA Cloud menu, select Miscellaneous, select Exports, and then select Scheduled Exports.
  2. Click New.
  3. Select the Responsys_Prop_Auto export and click Run.
  4. Specify the scheduler frequency and click OK.
Export Output
The Responsys Property export output file contains the following fields:
  • Export File Name Format. ' pms_p.resort ‘|| '_' ||RESPONSYS|| '_' ||PROPERTY|| '_' ||EXPORT|| '_' ||to_char(pms_p.business_date,'YYYYMMDDHHMI'). The following is an example: TOKYO_RESPONSYS_PROPERTY_EXPORT_202002141635.
  • File Extension. CSV.
Table 8-5 Export Fields
Column Type and Length Description
Property Name
VARCHAR (20 BYTE)
The property that the record belongs to.
Property Brand
VARCHAR (20 BYTE)
Chain Code for the chain to which the property belongs.
Property Type
VARCHAR (20 BYTE)
Type of resort.
Street Address
VARCHAR2(2000 BYTE)
The street of the property.
City
VARCHAR2(24 BYTE)
The physical city in which this property resides.
State
VARCHAR2(3 BYTE)
The state in which this property is located.
Postal Code
VARCHAR2(20 BYTE)
The postal code of this property.
Country
VARCHAR2(3 BYTE)
The name of the country in which this property resides.
No. of Guest Rooms
NUMBER
Total number of rooms in this property.
NUMBER(4,0)
Total number of Meeting rooms.
Attractions
Text (225)
The phone number for this record.
Airports
VARCHAR2(100 BYTE)
The Airport Code for the airport near the property.
Transportation
VARCHAR2(40)
Code of the transportation.
Alternatives
VARCHAR2(20)
Alternate property of the resort column.
Major_City_Nearby
VARCHAR2(20)
Marketing citycodes.
Region
VARCHAR2(20)
Region
