Configuring SFTP Destinations
Secure FTP (SFTP) is a secure way to transfer exports and scheduled reports to remote servers.
SSH Options For SFTP
| SSH Option | Supported Values |
| ECDSA |
| Public Key Algorithm |
Adding SFTP Configuration
The SFTP Hostname must be added to the Outbound Domain Allowlist prior to being configured. The default port for Secure FTP (SFTP) is 22. For more information, see Configuring Outbound Domain Allow Listings.-
                        From the Toolbox menu, select System Setup , and then SFTP Configuration.
                        Click New and complete the following: -
                              Context: Select a value from the list. -
                                    Global: Select to define a chain-level SFTP configuration available to all properties.
                                    Property: Select to define a property-specific SFTP configuration.
                              SFTP Code: Enter Unique SFTP Code you want to create, preferably with the following recommended format: -
                                    When creating at Chain Level use CHAIN CODE+SFTP CODE.
                                    When creating at Property Level use PROP CODE+SFTP CODE.
                              Description: Enter a description.
                              Hostname: Enter the SFTP Server Hostname.
                              Port Number: Enter the Port Number.
                              Auth Type: Select a value from the list.
                              Password: Enter password to authenticate using basic authentication method such as user account and password details.
                              Key:Enter key to authenticate using open authorization method such as OAuth Token URL and credential details.
- Key with Passphrase: Enter key phrase to authenticate using open authorization details like, OAuth Token URL and credential details.
                              Username: Enter the username.
                              Private Key: Enter the private key.
                              Passphrase: Enter the passphrase.
                              Host Key: Enter the public key of the server specified in Hostname (the server's public key).
                        Click Save.
Editing SFTP Configuration
                        Enter search criteria and click Search.
                        Select the SFTP in search result, click the vertical ellipsis Actions menu and select Edit. -
                              Update configuration.
                              Inactive: Select the checkbox to set the SFTP connection inactive. Deselect the checkbox to activate.
                        Click Save.
Validating SFTP Connectivity
                        Select the SFTP Code in search results, click the vertical ellipsis Actions menu and select Edit.
                        Click Add Rows to add folder and folder path. -
                              Folder Name: Enter the logical name for the specified folder path.
                              Folder Path: Enter the folder path. Note: Each folder must be validated prior to saving the SFTP configuration. Refresh the page to view validation status.-
                                    Click the vertical ellipsis Actions menu and select Validate.
                                    Select Refresh to view the validation status of each folder.
                                    Click Save.
Deleting SFTP Configuration
Ensure the SFTP Hostname is also removed from the Outbound Domain Allowlist. For more information, see Configuring Outbound Domain Allow Listings.-
                        Select the SFTP in search result, click vertical ellipsis Actions menu and select Delete.
                        Click Delete to confirm.
Parent topic: System Setup
