Configuring Multi Transaction Code Rate Codes
Prerequisites for Configuring Multi Transaction Code Rate Codes.
You can use either room classes or room types to associate transaction codes to a specific rate code, but not both simultaneously. Lodging revenue generated on one reservation and routed to another room is posted to the transaction code linked to the room type or room class of the originating reservation and not that of the receiving reservation.Adding Rate Code Multi Transaction Code Details
From the Administration menu, select Financial, select Rate Management, and then select Rate Codes.
Enter search criteria then click Search.
Select the rate code in the search result then click vertical ellipsis Actions menu and select Edit.
Click Financials.
Click Edit.
Select either Room Type or Room Class.
Transaction Code: Select an accommodation charge transaction code for each room class or room type listed
Click OK.
Click Save.
Editing Rate Code Multi Transaction Code Details
Click Financials.
Click Edit.
Click Edit Details.
Update transaction code selection for each room class or room type listed.
Click OK.
Click Save.
Parent topic: About Rate Codes
