Configuring Rotation Adjustment Reasons
Rotation Adjustment Reasons are used to identify why you are adjusting the assigned rotation points for a room or for a reservation.
In multi-property operations, rotation adjustment reasons are available to all properties.Adding Rotation Adjustment Reasons
From the Administration, select Inventory, select Room Rotation, then select Rotation Adjustment Reasons.
Click New and complete the following:
Code: Enter code for the rotation adjustment reason.
Description: Enter description for the rotation adjustment reason.
Manage Translations: Click link to configure localized descriptions. For more information, see Configuring Localized Code Descriptions. (Available when the Multi Language OPERA Control is active.).
Sequence: Enter a display sequence for the rotation adjustment reason in lists.
Click Save or click Save and Continue to add another.
Editing Rotation Adjustment Reasons
Enter search criteria then click Search.
Select the rotation adjustment reason code, then click the vertical ellipsis Actions menu and select Edit.
Update the configuration.
Click Save.
Deleting Rotation Adjustment Reasons
Select the rotation adjustment reason code, then click the vertical ellipsis Actions menu and select Delete.
Click Deleteto confirm.
Parent topic: About Room Rotation
