Packages Resynchronization
This synch is only available from ORS to OPERA Cloud PMS.
  1. From the Exchange menu, select Interface Resync, and then select Packages.
  2. The Type and Property values are taken by default. Search and select an Interface that is to be resynced.
  3. In the Packages to Resynchronize panel, select From Start Date and To Start Date for the resync.
  4. Select Packages. This option is to find only Packages that are not linked to groups. This option is usually the most desired for Resync choice and is the default upon entering this screen.
  5. Select Groups. This option is to find only Packages that are linked to groups.
  6. Search and select the Packages Codes.
  7. Click Resync History or Resync.
