Calculating or Expiring Membership Points and Issuing Award
Use Calculate Membership Points to calculate member points, expire award points, or issue (Other) awards to members in a batch process.
Calculating Membership Points
The Calculate Member Points process can be run for any membership type. This process references the point calculation rules and applies points to the member based on their activity (membership transactions)..
From the OPERA Cloud menu, select Client Relations, select Membership, then select Calculate Membership Points.
Select Calculate Points.
Membership Type: Select a membership type from the list
Calculate Until: Enter or select a date.
This date cannot be greater than the current date, minus the Delay in Days specified in the membership type. -
Click Submit.
The Expire Points process can be run for any membership type. This process references the Award Points Expiry Period and Expiration Date. Expired points are not available for redemption. Membership transactions with a type of Expired are applied. You can check a members points to expire using the Points to Expire link in the profile memberships
Select Expire Points.
Calculate Until: Enter or select a date .
Click Submit.
Issuing Membership Awards
This process will deduct all points from all members for the selected membership type.-
Select Issue Awards.
Membership Type: Select a membership type from the list.
Award: Select an award from the list.
Click Submit.
Parent topic: Membership (Loyalty Cloud Service)
