Configuring Cashiers
Cashier IDs are required to track every charge and payment posted to reservation and AR accounts. In multi-property operations cashier IDs are shared across all properties, allowing a cashier to post charges and payments in any property, according to their role and hub assignment, for more information, see Managing Users.
When the Foreign Currency Codes OPERA Control is active, you can configure foreign currency starting amounts. These amounts are indicated when closing cashiers. For more information, see section Configuring Cashier Starting Amounts.
Payment and charge transaction details are then available on financial reports and cashier closure reports.
You can automate the creation and assignment of cashiers to users by configuring an LDAP template
cashier and assigning users the <ORG>_OPERACASHIER role. The
auto-created cashiers inherit the template cashier attributes such as
Starting Amount, Maximum Daily
Uses and so on.
A cashier ID must be configured for the Night Audit Cashier ID OPERA Control and the Income Audit Cashier ID OPERA Control when the Income Audit OPERA Control is active. Cashiers must also be configured for each property interface that posts charges to OPERA Cloud. For example, Point of Sale, Video, Minibar, PBX / Call Accounting, and Leisure: Spa / Golf.
Adding Cashiers
From the Administration menu, select Financial, select Cashiering Management, then select Cashiers.
Click New and complete the fields and options on the Manage Cashier screen.
Cashier ID: Defaults to the next available cashier number in sequence. Enter a lower number to override the default.
Name: Enter the cashier's name. This could be the name of a person, the name of a shift, or other descriptive term to associate with this cashier ID. (Maximum 2000 characters).
Starting Amount: Enter the local currency starting balance assigned to the cash drawer for employees signing on with this cashier ID.
If you choose to work with fixed starting balances, enter the opening amount of each cashier's float (or bank) in this field. This is the amount the employee retains in the cash drawer and carries forward to the next day. If your policy requires cashiers to completely empty their cash drawer each night and deposit all the money in their banks into the safe, then your property is working without fixed starting balances and no entry is required. The starting amount is reflected on the Cashier Closure Report.
Users: Select one or more users to assign to this cashier ID. You cannot select user(s) already selected for another cashier. You cannot assign more than one user to the cashier when the Exclusive Cashier ID OPERA Control is active. You cannot remove a user when the cashier is open.
Reserved: Select a property from the list to assign exclusively to the cashier. You cannot select a Users when a reserved property is selected. (Available when the Reserved Cashier OPERA Control is active). Property cannot be changed when the cashier status is open or if the Cashier ID is explicitly associated with a user.
Maximum Daily Uses: Enter the number of times cashiers can close and re-open their cashier in one business day.
At the end of each shift, the cashier is balanced and closed. After closing, you must re-open before you can post another transaction. You can set the maximum daily user from 0 to 9999 (unlimited). For security purposes, you might want to restrict users to one or two uses per business day. Enter the number 1 here if you do not want a cashier reopened after it has been closed.
Type: Select a cashier type.
- Cashier: Select to configure this cashier ID for a standard user cashier. This is the default.
- Interface Cashier: Select if the cashier ID is reserved for use by interfaces.
- LDAP Template: Select to use this cashier ID as a template. This template is then used for automatically creating and assigning cashier IDs, to users granted the <ORG>_OPERACASHIER role, The cashier IDs created for users inherits the attributes set on this template Cashier (e.g., Starting Amount, Maximum Daily Uses, etc.). The Cashier Name is taken from the login User Name and a Cashier ID number is assigned by OPERA Cloud. Only one LDAP Template cashier ID can be created.
Kiosk Cashier: Select check box if this cashier ID is reserved for use by Kiosk applications. This cashier ID is not available for selection from the Cashier ID list of values on the Cashier Login screen. Only one Kiosk Cashier can be created and it cannot be selected as LDAP Template. This option is enabled when the OPP_KSK integration service is active.
Float Over/Short: Select check box if the cashier is able to drop above or below the required drop amount.
OPERA Cloud maintains a running total of any differences that might occur between the cash amount posted by the cashier and the cash amount the cashier actually entered during cashier closing. OPERA Cloud adds or subtracts the difference (depending on whether the cash amount is over or short) and updates the total accordingly.
LDAP Template: Select to use this cashier ID as a template. This template is then used for automatically creating and assigning cashier IDs, to users granted the <ORG>_OPERACASHIER role. The cashier IDs created for users inherits the attributes set on this template Cashier (e.g., Starting Amount, Maximum Daily Uses, etc.). The Cashier Name is taken from the login User Name and a Cashier ID number is assigned by OPERA Cloud. Only one LDAP Template cashier ID can be created.
Click Save.
Editing Cashiers
Enter search criteria and click Search.
Click the row level vertical ellipsis Actions menu for the cashier and select Edit.
Update the configuration.
Inactive. Select to set the cashier inactive.
If a Cashier ID is attached to a user or a control setting, you cannot make the cashier inactive. (A message alerts you that dependencies exist).
Click Save.
Adding Cashier Starting Amounts
The Amounts action is not available if the cashier you selected is open; close the cashier in order to add starting amounts.-
- Select the cashier in the search result, then click the vertical ellipsis Actions menu and select Amount.
Click New and complete following:
Currency Code: Select a currency code from the list.
Amount: Enter a starting amount.
Click Save.
Editing Cashier Starting Amounts
Select the cashier in the search result, then click the vertical ellipsis Actions menu for the cashier and select Amount.
Select the currency code in the search result, then click the vertical ellipsis Actions menu and select Edit.
Update the details.
Click Save.
Deleting Cashier Starting Amounts
Select the currency code in the search result, then click the vertical ellipsis Actions menu and select Delete.
Click Delete to confirm.
Parent topic: Configuring Cashiering Components
