Business Events - Block
The following table outlines the action types, data elements, data types and XML tag names within this OPERA Cloud Business Events module.
| Action Type | Data Element | Data Type | XML Tag | Description |
BLOCK RESTRICTIONS |
ARRIVAL |
C |
Arrival |
BLOCK ID |
N |
BlockId |
BOOK MAX ADV |
N |
BookMaxAdv |
BOOK MIN ADV |
N |
BookMinAdv |
DAY OF WEEK |
C |
DayOfWeek |
DEPARTURE |
C |
Departure |
LENGTH OF STAY NA |
C |
LengthOfStayNA |
MAX LOS |
N |
MaxLos |
MAX STAY THROUGH |
N |
MaxStayThrough |
MIN LOS |
N |
MinLos |
MIN STAY THROUGH |
N |
MinStayThrough |
ROOM TYPE |
C |
RoomType |
SET ON |
C |
SetOn |
STAY |
C |
Stay |
DELETE BLOCK HEADER |
ALIAS |
C |
Alias |
ARRIVAL TIME |
T |
ArrivalTime |
BLOCK CODE |
C |
BlockCode |
The Block Code of the Block. This does not need to be unique based on application parameter UNIQUE BLOCK CODE. |
BLOCK NAME |
C |
BlockName |
BLOCK TYPE |
C |
BlockType |
BOOKING STATUS |
C |
BookingStatus |
Status will be shown as CAN for cancelled blocks. |
BOOKING TYPE |
C |
BookingType |
CAT STATUS |
C |
CatStatus |
CATERING ONLY YN |
C |
CateringOnlyYn |
CHANNEL |
C |
Channel |
COMMISSION |
C |
Commission |
COMPANY NAME |
C |
CompanyName |
COMPANY NAME ID |
N |
CompanyNameId |
CONTROL BLOCK LOCALLY |
C |
ControlBlockLocally |
CREDIT CARD NUMBER |
C |
CreditCardNumber |
CURRENCY CODE |
C |
CurrencyCode |
The currency code that the block was created in. |
CUTOFF DATE |
D |
CutoffDate |
The date when the system will release any non-picked up rooms and put back into inventory. |
CUTOFF DAYS |
N |
CutoffDays |
The number of days before the arrival date when the system will release any non- picked up rooms and put back into inventory. |
DATES FLEXIBLE |
C |
DatesFlexible |
DECISION DATE |
D |
DecisionDate |
DEPARTURE TIME |
T |
DepartureTime |
ELASTIC BLOCK |
N |
ElasticBlock |
Is this Block allowed to have reservations made outside the block date? |
END DATE |
D |
EndDate |
The UPDATE BLOCK HEADER business event will not be triggered for business blocks that are updated and have an End Date prior to the current business date. |
EXTERNAL LOCKED |
C |
ExternalLocked |
FOLLOW UP DATE |
D |
FollowUpDate |
GROUP NAME |
C |
GroupName |
Refers to the Group Profile Name attached to the Block. Block name is the name of the Business Block. |
GROUP NAME ID |
N |
GroupNameId |
GSO ASSOCIATE |
C |
GsoAssociate |
GSO SENDING LOCATION |
C |
GsoSendingLocation |
GUARANTEE REQUIRED |
C |
GuaranteeRequired |
INSERT DATE |
D |
InsertDate |
This doesn't apply to Block Grids as Insert Data is not available for inserting availability in the grid. Update Block Header would give you the Update Date. |
INSERT USER |
N |
InsertUser |
ISAC OPPTY ID |
C |
IsacOpptyId |
LINK DATE |
D |
LinkDate |
MARKET CODE |
C |
MarketCode |
OPPTY CREATED DATE |
D |
OpptyCreatedDate |
ORIGINAL BEGIN DATE HOLIDEX |
D |
OriginalBeginDateHolidex |
PAYMENT METHOD |
C |
PaymentMethod |
PRINT RATE FLAG |
C |
PrintRateFlag |
PRODUCTS |
C |
Products |
The add-on packages that have been attached to the block or are attached by default because a Package is attached to the Rate Code on the Block Header. |
RATE CODE |
C |
RateCode |
The rate code that has been attached to the block. There is no relationship between a group and a rate code. A rate code can be used for both transient and block reservation. A business practice could be to only use specific rate codes for blocks, but OPERA would not force this functionality. |
RESERVATION METHOD |
C |
ReservationMethod |
RESERVATION TYPE |
C |
ReservationType |
The default reservation type for all reservations made against this block. If a Block has a Block Status of 'O' Open for Pickup, the Reservation Type should be used to determine if the Rooms Held are Deduct or Non-Deduct from Inventory. |
RESERVE INVENTORY |
C |
ReserveInventory |
Value will be populated with Y or N. When Y, the Block rooms are deduct from inventory. This is relevant when Block Status is 'O' - Open for Pickup. This Block Status alone does not represent whether the inventory is deduct or non deduct. This element is released in Version 2.6. |
RESPONSE DUE DATE |
D |
ResponseDueDate |
ROOMING LIST DUE |
D |
RoomingListDue |
SELL THRU |
C |
SellThru |
SHOULDER END DATE |
D |
ShoulderEndDate |
SHOULDER END RATE |
C |
ShoulderEndRate |
SHOULDER START RATE |
C |
ShoulderStartRate |
SHOULDER STARTING DATE |
D |
ShoulderStartingDate |
SOURCE CODE |
C |
SourceCode |
SOURCE NAME |
C |
SourceName |
SOURCE NAME ID |
N |
SourceNameId |
STARTING DATE |
D |
BLKStartDate |
STATUS |
C |
BLKStatus |
The current block status. 'C'=Returns all held rooms to inventory; 'F'= Not open for Pickup, do not deduct rooms from inventory; 'I'= Not open for pickup, deduct from inventory; 'O'= Open for pickup. This alone does not determine whether or not to deduct rooms from inventory. When 'O' is received as the block status (status element) then the reservation type also needs to be considered. The reservation type determines if the rooms are deduct or non-deduct. 'P'=Not open for pickup. Do not deduct from inventory. This status is no longer used in OPERA, instead 'F' is assigned, however, blocks created in the past may indeed have this status. |
SUPER BLOCK CODE |
C |
SuperBlockCode |
If this block is a sub-block of another, what is the code of the main block? |
SUPER BLOCK ID |
C |
SuperBlockId |
If this block is a sub-block of another, what is the Block ID of the Main Block Header. In the case of Tour Series, the Super Block ID will be '-2'. |
SUPPRESS RATE FLAG |
C |
SuppressRateFlag |
SYNC CONTRACT |
C |
SyncContract |
TRACE CODE |
C |
TraceCode |
TRAVEL AGENT NAME |
C |
TravelAgentName |
TRAVEL AGENT NAME ID |
N |
TravelAgentNameId |
UPDATE USER |
N |
UpdateUser |
WEB BOOKABLE |
C |
WebBookable |
DELETE CONTRACT HEADER |
BLOCK NAME |
C |
BlockName |
CONTRACT NO |
C |
ContractNo |
LEADSTATUS |
C |
LeadStatus |
REPLY_STATUS |
C |
ReplyStatus |
DELETE LEAD HEADER |
ALIAS |
C |
Alias |
BLOCK CODE |
C |
BlockCode |
BLOCK NAME |
C |
BlockName |
CATERING ONLY YN |
C |
CateringOnlyYn |
CHANNEL |
C |
Channel |
COMPANY NAME |
C |
CompanyName |
COMPANY NAME ID |
N |
CompanyNameId |
C |
C |
CreditCardNumber |
CURRENCY CODE |
C |
CurrencyCode |
CUTOFF DATE |
D |
CutoffDate |
CUTOFF DAYS |
N |
CutoffDays |
DATES FLEXIBLE |
C |
DatesFlexible |
ELASTIC BLOCK |
N |
ElasticBlock |
END DATE |
D |
EndDate |
EXTERNAL LOCKED |
C |
ExternalLocked |
GROUP NAME |
C |
GroupName |
GROUP NAME ID |
N |
GroupNameId |
C |
GuaranteeRequired |
INSERT DATE |
D |
InsertDate |
MARKET CODE |
C |
MarketCode |
PAYMENT METHOD |
C |
PaymentMethod |
PRODUCTS |
C |
Products |
RATE CODE |
C |
RateCode |
RESERVATION TYPE |
C |
ReservationType |
RESERVE INVENTORY |
C |
ReserveInventory |
SOURCE CODE |
C |
SourceCode |
SOURCE NAME |
C |
SourceName |
SOURCE NAME ID |
N |
SourceNameId |
STARTING DATE |
D |
BLKStartDate |
STATUS |
C |
BLKStatus |
SUPER BLOCK CODE |
C |
SuperBlockCode |
SUPER BLOCK ID |
C |
SuperBlockId |
SYNC CONTRACT |
C |
SyncContract |
TRACE CODE |
C |
TraceCode |
TRAVEL AGENT NAME |
C |
TravelAgentName |
N |
TravelAgentNameId |
NEW BLOCK HEADER |
ALIAS |
C |
Alias |
ALLOTMENT CLASSIFICATION |
C |
AllotmentClassification |
ALLOTMENT ORIGION |
C |
AllotmentOrigion |
ARRIVAL TIME |
T |
ArrivalTime |
AVG PEOPLE PER ROOM |
N |
AvgPeoplePerRoom |
BLOCK CODE |
C |
BlockCode |
BLOCK NAME |
C |
BlockName |
BLOCK TYPE |
C |
BlockType |
BOOKING STATUS |
C |
BookingStatus |
BOOKING TYPE |
C |
BookingType |
CAT STATUS |
C |
CatStatus |
CATERING ONLY YN |
C |
CateringOnlyYn |
CHANNEL |
C |
Channel |
COMMISSION |
C |
Commission |
COMPANY NAME |
C |
CompanyName |
COMPANY NAME ID |
N |
CompanyNameId |
C |
CONVERSION CODE |
C |
ConversionCode |
C |
CreditCardNumber |
CURRENCY CODE |
C |
CurrencyCode |
CUTOFF DATE |
D |
CutoffDate |
CUTOFF DAYS |
N |
CutoffDays |
CXL PENALTY |
N |
CxlPenalty |
DATES FLEXIBLE |
C |
DatesFlexible |
DECISION DATE |
D |
DecisionDate |
DEPARTURE TIME |
T |
DepartureTime |
ELASTIC BLOCK |
N |
ElasticBlock |
END DATE |
D |
EndDate |
EXTERNAL LOCKED |
C |
ExternalLocked |
EXTERNAL RFP ID |
C |
ExternalRFPID |
EXTERNAL RFP SYSTEM |
C |
ExternalRFPSystem |
FB AGENDA CURR |
C |
FbAgendaCurr |
FOLLOW UP DATE |
D |
FollowUpDate |
GROUP NAME |
C |
GroupName |
GROUP NAME ID |
N |
GroupNameId |
GSO ASSOCIATE |
C |
GsoAssociate |
C |
C |
GuaranteeRequired |
HLX CANX NOTICE DAYS |
N |
HlxCanxNoticeDays |
HLX COMMISSIONABLE YN |
C |
HlxCommissionableYn |
HLX DEPOSIT DAYS |
N |
HlxDepositDays |
HLX RETURN EACH DAY YN |
C |
HlxReturnEachDayYn |
INSERT DATE |
D |
InsertDate |
INSERT USER |
N |
InsertUser |
ISAC OPPTY ID |
C |
IsacOpptyId |
LINK DATE |
D |
LinkDate |
MARKET CODE |
C |
MarketCode |
NON COMPETE |
C |
NonCompete |
NON COMPETE CODE |
C |
NonCompeteCode |
D |
OpptyCreatedDate |
D |
PAYMENT METHOD |
C |
PaymentMethod |
PRINT RATE FLAG |
C |
PrintRateFlag |
PRODUCTS |
C |
Products |
RANKING CODE |
C |
RankingCode |
RATE CODE |
C |
RateCode |
RATE GUARANTEED YN |
C |
RateGuaranteedYn |
RATE PROTECT |
C |
RateProtect |
C |
ReservationMethod |
RESERVATION TYPE |
C |
ReservationType |
RESERVE INVENTORY |
C |
ReserveInventory |
RESPONSE DUE DATE |
D |
ResponseDueDate |
ROOMING LIST DUE |
D |
RoomingListDue |
SELL THRU |
C |
SellThru |
SHOULDER END DATE |
D |
ShoulderEndDate |
SHOULDER END RATE |
C |
ShoulderEndRate |
C |
ShoulderStartRate |
D |
SOURCE CODE |
C |
SourceCode |
SOURCE NAME |
C |
SourceName |
SOURCE NAME ID |
N |
SourceNameId |
STARTING DATE |
D |
BLKStartDate |
STATUS |
C |
BLKStatus |
SUPER BLOCK CODE |
C |
SuperBlockCode |
SUPER BLOCK ID |
C |
SuperBlockId |
C |
SuppressRateFlag |
SYNC CONTRACT |
C |
SyncContract |
TRACE CODE |
C |
TraceCode |
TRAVEL AGENT NAME |
C |
TravelAgentName |
N |
TravelAgentNameId |
UPDATE USER |
N |
UpdateUser |
WEB BOOKABLE |
C |
WebBookable |
UPDATE BLOCK GRID |
ALLOTTED BLOCKED |
N |
AllottedBlock |
BLOCK CODE |
C |
BlockCode |
BLOCK NAME |
C |
BlockName |
BLOCK SHIFT YN |
C |
BlockShiftYn |
CONTRACT |
N |
Contract |
CONTRACT OCC1 |
N |
ContractOcc1 |
CONTRACT OCC2 |
N |
ContractOcc2 |
CONTRACT OCC3 |
N |
ContractOcc3 |
CONTRACT OCC4 |
N |
ContractOcc4 |
CUTOFF DATE |
D |
CutoffDate |
CUTOFF DAYS |
N |
CutoffDays |
FIXED RATE YN |
C |
FixedRateYn |
GRID DATE |
D |
GridDate |
INITIAL BLOCKED |
N |
InitialBlocked |
INVENTORY CONTROL MODE |
C |
InventoryControlMode |
NUMBER OF ROOMS RELEASED |
N |
NumberOfRoomsReleased |
The number of rooms released when any non-picked up rooms are released back into inventory. Regardless if the system releases the rooms based on cutoff date or are released manually. |
ROOM TYPE |
C |
RoomType |
SELL LIMIT |
N |
SellLimit |
SELL LIMIT SOLD |
N |
SellLimitSold |
UPDATE BLOCK GRID SUMMARY |
BLOCK CODE |
C |
BlockCode |
BLOCK NAME |
C |
BlockName |
UPDATE BLOCK HEADER |
AGENT CONTACT NAME |
C |
AgentContactName |
AGENT CONTACT NAME ID |
N |
agentContactNameId |
ALIAS |
C |
Alias |
C |
ALLOTMENT ORIGION |
C |
AllotmentOrigion |
ALLOTMENT RATES |
C |
AllotmentRates |
ARRIVAL TIME |
T |
ArrivalTime |
ATTACHMENT CHANGED |
C |
AttachmentChanged |
ATTENDEES |
N |
attendees |
N |
AvgPeoplePerRoom |
BLOCK CODE |
C |
BlockCode |
BLOCK NAME |
C |
BlockName |
BLOCK TYPE |
C |
BlockType |
BOOKING STATUS |
C |
BookingStatus |
BOOKING TYPE |
C |
BookingType |
CAT DECISION |
D |
CatDecision |
CAT FOLLOWUP |
D |
CatFollowUp |
CAT STATUS |
C |
CatStatus |
CATERING ONLY YN |
C |
CateringOnlyYn |
CHANNEL |
C |
Channel |
COMMISSION |
C |
Commission |
COMPANY NAME |
C |
CompanyName |
COMPANY NAME ID |
N |
CompanyNameId |
CONTACT NAME |
C |
ContactName |
CONTACT NAME ID |
N |
contactNameId |
C |
CONVERSION CODE |
C |
ConversionCode |
C |
CreditCardNumber |
CURRENCY CODE |
C |
CurrencyCode |
CUTOFF DATE |
D |
CutoffDate |
CUTOFF DAYS |
N |
CutoffDays |
CXL PENALTY |
N |
CxlPenalty |
DATES FLEXIBLE |
C |
DatesFlexible |
DECISION DATE |
D |
DecisionDate |
DEPARTURE TIME |
T |
DepartureTime |
DETAILS OK YN |
C |
DetailsOkYn |
DISTRIBUTED DATE |
D |
DistributedDate |
DISTRIBUTED YN |
C |
DistributedYn |
ELASTIC BLOCK |
N |
ElasticBlock |
END DATE |
D |
EndDate |
EVENT GUARANTEED YN |
C |
EventGuarantedYn |
EXTERNAL CONTACT NAME |
C |
ExternalContactName |
EXTERNAL CONTACT NAME ID |
N |
ExternalContactNameId |
EXTERNAL LOCKED |
C |
ExternalLocked |
EXTERNAL RFP ID |
C |
ExternalRFPID |
C |
ExternalRFPSystem |
FB AGENDA CURR |
C |
FbAgendaCurr |
FOLLOW UP DATE |
D |
FollowUpDate |
GROUP NAME |
C |
GroupName |
GROUP NAME ID |
N |
GroupNameId |
GSO ASSOCIATE |
C |
GsoAssociate |
C |
C |
GuaranteeRequired |
N |
HlxCanxNoticeDays |
C |
HLX DEPOSIT DAYS |
N |
HlxDepositDays |
C |
INFO BOARD |
C |
infoBoardName |
INSERT DATE |
D |
InsertDate |
INSERT USER |
N |
InsertUser |
ISAC OPPTY ID |
C |
IsacOpptyId |
LINK DATE |
D |
LinkDate |
LOST TO PROPERTY |
C |
LostToProperty |
MARKET CODE |
C |
MarketCode |
NON COMPETE |
C |
NonCompete |
NON COMPETE CODE |
C |
NonCompeteCode |
D |
OpptyCreatedDate |
D |
PAYMENT METHOD |
C |
PaymentMethod |
PRINT RATE FLAG |
C |
PrintRateFlag |
PRODUCTS |
C |
Products |
RANKING CODE |
C |
RankingCode |
RATE CODE |
C |
RateCode |
C |
RateGuaranteedYn |
RATE OVERRIDE REASON |
C |
RateOverrideReason |
RATE OVERRIDE YN |
C |
RateOverrideYn |
RATE PROTECT |
C |
RateProtect |
C |
ReservationMethod |
RESERVATION TYPE |
C |
ReservationType |
RESERVE INVENTORY |
C |
ReserveInventory |
RESPONSE DUE DATE |
D |
ResponseDueDate |
ROOMING LIST DUE |
D |
RoomingListDue |
SELL THRU |
C |
SellThru |
SHOULDER END DATE |
D |
ShoulderEndDate |
SHOULDER END RATE |
C |
ShoulderEndRate |
C |
ShoulderStartRate |
D |
SOURCE CODE |
C |
SourceCode |
SOURCE CONTACT NAME |
C |
SourceContactName |
SOURCE CONTACT NAME ID |
N |
SourceContactNameId |
SOURCE NAME |
C |
SourceName |
SOURCE NAME ID |
N |
SourceNameId |
STARTING DATE |
D |
BLKStartDate |
STATUS |
C |
BLKStatus |
SUB ALLOTMENT |
C |
SubAllotment |
SUPER BLOCK CODE |
C |
SuperBlockCode |
SUPER BLOCK ID |
C |
SuperBlockId |
C |
SuppressRateFlag |
SYNC CONTRACT |
C |
SyncContract |
TRACE CODE |
C |
TraceCode |
TRAVEL AGENT NAME |
C |
TravelAgentName |
N |
TravelAgentNameId |
UPDATE USER |
N |
UpdateUser |
WEB BOOKABLE |
C |
WebBookable |
UPDATE BLOCK PICKUP |
BLOCK CODE |
C |
BlockCode |
BLOCK NAME |
C |
BlockName |
GRID DATE |
D |
GridDate |
PICK UP ROOMS |
N |
PickupRooms |
The number of rooms that have reservations made against the block. |
ROOM TYPE |
C |
RoomType |
SELL LIMIT SOLD |
N |
SellLimitSold |
UPDATE BLOCK SECURITY |
BLOCK CODE |
C |
BlockCode |
BLOCK NAME |
C |
BlockName |
HLX DD SECURED YN |
C |
HlxDdSecuredYn |
HLX DI SECURED YN |
C |
HlxDiSecuredYn |
HLX HOUSINGINFO SECURED YN |
C |
HlxHousinginfoSecuredYn |
HLX RATE ALL SECURED YN |
C |
HlxRateAllSecuredYn |
HLX RATES GNR SECURED YN |
C |
HlxRatesGnrSecuredYn |
UPDATE BUSINESSBLOCK LINKS |
N |
ALIAS |
C |
Alias |
ALLOTMENT ORIGION |
C |
AllotmentOrigion |
ARRIVAL TIME |
T |
ArrivalTime |
BLOCK CODE |
C |
BlockCode |
BLOCK NAME |
C |
BlockName |
BLOCK TYPE |
C |
BlockType |
BOOKING STATUS |
C |
BookingStatus |
BOOKING TYPE |
C |
BookingType |
CAT STATUS |
C |
CatStatus |
CATERING ONLY YN |
C |
CateringOnlyYn |
CHANNEL |
C |
Channel |
COMMISSION |
C |
Commission |
COMPANY NAME |
C |
CompanyName |
COMPANY NAME ID |
N |
CompanyNameId |
CONTACT NAME ID |
N |
contactNameId |
C |
C |
CreditCardNumber |
CURRENCY CODE |
C |
CurrencyCode |
CUTOFF DATE |
D |
CutoffDate |
CUTOFF DAYS |
N |
CutoffDays |
CXL PENALTY |
N |
CxlPenalty |
DATES FLEXIBLE |
C |
DatesFlexible |
DECISION DATE |
D |
DecisionDate |
DEPARTURE TIME |
T |
DepartureTime |
ELASTIC BLOCK |
N |
ElasticBlock |
END DATE |
D |
EndDate |
EXTERNAL LOCKED |
C |
ExternalLocked |
FB AGENDA CURR |
C |
FbAgendaCurr |
FOLLOW UP DATE |
D |
FollowUpDate |
GROUP NAME |
C |
GroupName |
GROUP NAME ID |
N |
GroupNameId |
GSO ASSOCIATE |
C |
GsoAssociate |
C |
C |
GuaranteeRequired |
N |
HlxCanxNoticeDays |
C |
HLX DEPOSIT DAYS |
N |
HlxDepositDays |
C |
INSERT DATE |
D |
InsertDate |
INSERT USER |
N |
InsertUser |
ISAC OPPTY ID |
C |
IsacOpptyId |
LINK DATE |
D |
LinkDate |
LOST TO PROPERTY |
C |
LostToProperty |
MARKET CODE |
C |
MarketCode |
D |
OpptyCreatedDate |
D |
PAYMENT METHOD |
C |
PaymentMethod |
PRINT RATE FLAG |
C |
PrintRateFlag |
PRODUCTS |
C |
Products |
RATE CODE |
C |
RateCode |
C |
ReservationMethod |
RESERVATION TYPE |
C |
ReservationType |
RESERVE INVENTORY |
C |
ReserveInventory |
RESPONSE DUE DATE |
D |
ResponseDueDate |
ROOMING LIST DUE |
D |
RoomingListDue |
SELL THRU |
C |
SellThru |
SHOULDER END DATE |
D |
ShoulderEndDate |
SHOULDER END RATE |
C |
ShoulderEndRate |
C |
ShoulderStartRate |
D |
SOURCE CODE |
C |
SourceCode |
SOURCE NAME |
C |
SourceName |
SOURCE NAME ID |
N |
SourceNameId |
STARTING DATE |
D |
BLKStartDate |
STATUS |
C |
BLKStatus |
SUB ALLOTMENT |
C |
SubAllotment |
SUPER BLOCK CODE |
C |
SuperBlockCode |
SUPER BLOCK ID |
C |
SuperBlockId |
C |
SuppressRateFlag |
SYNC CONTRACT |
C |
SyncContract |
TRACE CODE |
C |
TraceCode |
TRAVEL AGENT NAME |
C |
TravelAgentName |
N |
TravelAgentNameId |
UPDATE USER |
N |
UpdateUser |
UPDATE CONTRACT HEADER |
C |
BLOCK NAME |
C |
BlockName |
CONTACT NAME ID |
N |
contactNameId |
CONTRACT NO |
C |
ContractNo |
FIT CONTRACT MODE |
C |
FitContractMode |
LEADSTATUS |
C |
LeadStatus |
REPLY_STATUS |
C |
ReplyStatus |
UPDATE INVENTORY CONTROL MODE |
C |
UPDATE LEAD GRID |
ALLOTTED BLOCKED |
N |
AllottedBlock |
BLOCK CODE |
C |
BlockCode |
BLOCK NAME |
C |
BlockName |
CONTRACT |
C |
Contract |
CONTRACT OCC1 |
N |
ContractOcc1 |
CONTRACT OCC2 |
N |
ContractOcc2 |
CONTRACT OCC3 |
N |
ContractOcc3 |
CONTRACT OCC4 |
N |
ContractOcc4 |
CUTOFF DATE |
D |
CutoffDate |
CUTOFF DAYS |
N |
CutoffDays |
GRID DATE |
D |
GridDate |
INITIAL BLOCKED |
N |
InitialBlocked |
N |
ROOM TYPE |
C |
RoomType |
UPDATE LEAD HEADER |
C |
AgentContactName |
N |
AgentContactNameId |
ALIAS |
C |
Alias |
C |
ALLOTMENT ORIGION |
C |
AllotmentOrigion |
BLOCK CODE |
C |
BlockCode |
BLOCK NAME |
C |
BlockName |
CATERING ONLY YN |
C |
CateringOnlyYn |
CHANNEL |
C |
Channel |
COMPANY NAME |
C |
CompanyName |
COMPANY NAME ID |
N |
CompanyNameId |
CONTACT NAME |
C |
ContactName |
CONTACT NAME ID |
N |
ContactNameId |
C |
C |
CreditCardNumber |
CURRENCY CODE |
C |
CurrencyCode |
CUTOFF DATE |
D |
CutoffDate |
CUTOFF DAYS |
N |
CutoffDays |
DATES FLEXIBLE |
C |
DatesFlexible |
ELASTIC BLOCK |
N |
ElasticBlock |
END DATE |
D |
EndDate |
EXTERNAL LOCKED |
C |
ExternalLocked |
EXTERNAL RFP ID |
C |
ExternalRFPID |
C |
ExternalRFPSystem |
FB AGENDA CURR |
C |
FbAgendaCurr |
GROUP NAME |
C |
GroupName |
GROUP NAME ID |
N |
GroupNameId |
C |
GuaranteeRequired |
INSERT DATE |
D |
InsertDate |
LEADSTATUS |
C |
LeadStatus |
MARKET CODE |
C |
MarketCode |
PAYMENT METHOD |
C |
PaymentMethod |
PRODUCTS |
C |
Products |
RATE CODE |
C |
RateCode |
REPLY_STATUS |
C |
ReplyStatus |
RESERVATION TYPE |
C |
ReservationType |
RESERVE INVENTORY |
C |
ReserveInventory |
SOURCE CODE |
C |
SourceCode |
C |
SourceContactName |
N |
SOURCE NAME |
C |
SourceName |
SOURCE NAME ID |
N |
SourceNameId |
STARTING DATE |
D |
BLKStartDate |
STATUS |
C |
BLKStatus |
SUPER BLOCK CODE |
C |
SuperBlockCode |
SUPER BLOCK ID |
C |
SuperBlockId |
SYNC CONTRACT |
C |
SyncContract |
TRACE CODE |
C |
TraceCode |
TRAVEL AGENT NAME |
C |
TravelAgentName |
N |
TravelAgentNameId |
UPDATE LEAD NOTES |
ALLOTMENT_HEADER_ID |
N |
AllotmentHeaderId |
EXTERNAL_ID |
N |
Externalid |
INTERNAL_YN |
C |
InternalYn |
NOTES |
C |
Notes |
NOTE_CODE |
C |
NoteCode |
NOTE_ID |
N |
NoteId |
NOTE_TITLE |
C |
NoteTitle |
RESORT |
C |
Resort |
UPDATE LEAD RATES |
1 PERSON RATE |
N |
OnePersonRate |
2 PERSON RATE |
N |
TwoPersonRate |
3 PERSON RATE |
N |
ThreePersonRate |
4 PERSON RATE |
N |
FourPersonRate |
ADDITIONAL PERSON |
N |
AdditionalPerson |
BLOCK CODE |
C |
BlockCode |
BLOCK NAME |
C |
BlockName |
GRID DATE |
D |
GridDate |
ROOM TYPE |
C |
RoomType |
UPDATE RATES |
1 PERSON RATE |
N |
OnePersonRate |
2 PERSON RATE |
N |
TwoPersonRate |
3 PERSON RATE |
N |
ThreePersonRate |
4 PERSON RATE |
N |
FourPersonRate |
ADDITIONAL PERSON |
N |
AdditionalPerson |
BLOCK CODE |
C |
BlockCode |
BLOCK NAME |
C |
BlockName |
BLOCK SHIFT YN |
C |
BlockShiftYn |
GRID DATE |
D |
GridDate |
ROOM TYPE |
C |
RoomType |
Parent topic: Business Events Modules
