Using Quick Check-Out
Quick Check Out is a fast way to check out reservations when the payment method is credit card or direct bill or the reservation has a zero balance.
To ensure a successful Quick Check Out:
  • Make sure the guest's credit card has sufficient authorization to cover the balance.
  • Make sure Direct Bill AR accounts are not restricted and have not exceeded credit limits.
  • Make sure cash guest folios have a zero balance.
Watch VideoWatch Video
Mass Check Out Reservations
Mass check out steps you through the settlement and checkout of each reservation
  1. From the OPERA Cloud menu, select Front Desk , select Front Desk Workspace, and then select Quick Check Out.
  2. Enter search criteria then click Search.
  3. Select the Table or List view
  4. Select multiple reservations in the search result then click Mass Check Out.
  5. Folio Settlement appears for the first reservation
    1. Enter payment details
    2. Click Settle and Send Folio.
      1. Report Destination
        1. Select a Folio Style.
        2. Select a Report Destination.
        3. Click Process.
    3. Click Check Out Now to check out the reservation or click Schedule Check Out to schedule the check out for a later time. For more information, see Scheduling a Checkout.
    4. Select a room status.
    5. Click Save.
  6. Repeat step 5 for the next reservation.
Auto (Settlement) Check Out Reservations
Auto checkout processes credit card or direct bill settlements and checks out the reservation automatically. The room status is updated according to the Room Status for Zero Balance and Auto Checkouts OPERA Control. A status panel will display the progress for each reservation.
When the Auto Check Out Fiscal Folios OPERA Control is enabled, fiscal folios are settled automatically after you select Auto Check Out on the Quick Check Out screen.
  3. Select the Table or List view.
  4. Select multiple reservations in the search result then click Auto Check Out.
Check Out All Zero Balance Due Out Reservations
Use this option to check out all due reservations with a zero balance. The room status gets updated according to the Room Status for Zero Balance and Auto Checkouts OPERA Control.
When the Batch Folio Printing for Zero Balance Checkouts OPERA Control is active, the option for batch folio printing becomes available for reservations with a zero balance checkout. This applies when the amount has been paid, but no folio has been generated. If the email folio option is selected for a guest who has a valid email address, the folio will be sent to that specified email address.
  2. Click Check Out Zero Balance Departures.
  3. A status screen displays the progress.
    1. For all reservations that were checked out successfully, Successfully Processed is displayed.
    2. For any reservation that is not checked out successfully, a message indicating the reason is displayed.
The following are scenarios and their expected outcome when using the Check Out Zero Balance Departures.
Table 4-3 Scenarios and expected outcome
# Reservation Status Scenario Outcome
1
Day Use
Reservation has zero rate and Zero Reservation Balance  * Windows has no postings
Checked Out Successfully
2
Day Use
Reservation has zero rate and Zero Reservation Balance  * Windows has postings but settled and no folio generated
Checked Out Successfully  and Folio Generated
3
Day Use
Reservation has zero rate and Zero Reservation Balance  * Windows have charges/payments and at least one or more windows balance is non zero
Error Shown  "Reservation has a balance, checkout cannot be processed"
4
Day Use
Reservation has Non Zero Rate and Zero Guest Balance  * Windows has no postings
Charged are posted Error Shown  "Reservation has a balance, checkout cannot be processed"
5
Day Use
Reservation has Non Zero Rate and Zero Reservation Balance  * Windows has postings but settled and no folio generated
6
Day Use
Reservation has Non Zero Rate and Zero Reservation Balance  * Windows have charges/payments and at least one or more windows balance is non zero
7
Due Out
8
Due Out
9
Due Out
Reservation has Non Zero Rate, zero reservation balance and payment method configured is Direct Bill. But the payee does not have AR number configured. Payment is posted against the charges using different payment method and folio is not generated.
Error Shown  "AR Acocunt does not Exist"
10
Due Out
If Folio requires Fiscal Printing
Error Shown " The Folio requires the Fiscal Printing, please process the checkout manually."
Related Topics
