Configuring Block Conversions
Adding Block Conversion
Select the Administration menu, select Booking, select Block Management, and then select Conversions.
Click New and complete the following fields:
Code: Enter a code (up to 10 characters) for the conversion rating.
Description: Enter a text description of the conversion rating.
Sequence: Enter a number that controls the position of this code in listings. Codes without a sequence number assigned are listed in alphabetical order following codes with a sequence assigned.
Click Save.
Editing Block Conversion
Enter search criteria and click Search.
Select the block conversion code in the search result, then click the vertical ellipsis Actions menu and select Edit.
Update the configuration
Inactive: Select to mark this code inactive. Inactive codes are not available for selection from lists. The code remains for historical and statistical purposes only.
Click Save.
Deleting a Block Conversion
- Select the block conversion code in the search result, then click the vertical ellipsis Actions menu and select Delete.
Click Delete to confirm.
