Managing Blocks Traces
Adding Block Traces
From the OPERA Cloud menu, select Bookings, select Blocks, and then select Manage Block.
Enter search criteria and click Search.
Select the block in the search result, click I Want To..., Traces or click the Traces link in Block Presentation.
Click New and complete the following:
Department. Select the department(s) for trace.
From Date: Enter a From date.
To Date: Enter a To date.
Time: Enter time.
Trace text: Enter the trace text.
Quick Insert: Click to select from pre-configured trace text for the selected department. Configuring Trace Texts.
Click Save.
Updating Block Traces
Only open traces are displayed by default, to view completed traces click Vertical Ellipsis, Show Completed.-
Enter block criteria, click Search.
Click + to expand the card and view trace details.
Click and select Edit.
Update details.
Click Save.
Resolving / Completing Block Traces
Enter search criteria, click Search.
Click the vertical ellipsis Actions menu and select Complete.
Deleting Block Traces
Click the vertical ellipsis Actions menu, and select Delete.
Click Delete to confirm.
