Managing Interface (External System) Status
Activating the external system is the final step to start generating business events for the external system.
To stop generating business events, you need to inactivate the external system.
Activating External Systems
From the Exchange menu, select Interface Setup then select Interface Setup.
Enter search criteria, then click Search.
Select the interface in the search result, then click I Want to... and select Activate External System.
Inactivating External Systems
Select the interface in the search result, then click I Want to... and select Inactivate External System.
