OPERA Controls — General
The following tables outline the functions, parameters, and settings that can be configured in the OPERA Controls General group.
Table 12-41 OPERA Controls — General Functions
| FUNCTION | RELATED FUNCTION / PARAMETER / SETTING | DESCRIPTION |
AUTO CONFIGURE OXI-OPERA INTERFACE SETUP [AUTOCREATE_INTERFACE_CONFIGURATIONS] |
Auto configures all pre-requisite interface setup needed
for integrating OPERA Cloud Central with OPERA PMS at individual property
level.
Note: This function is not meant for Non-OPERA PMS or other OXI-HUB interfaces.Tip:
AUTO CONFIGURE OXI-OPERA INTERFACE SETUP FOR ALL CENTRAL PROPERTIES [AUTOCREATE_INTERFACE_CONFIGURATIONS_GLOBAL] |
for integrating OPERA Cloud Central with OPERA PMS for all properties
in the chain. This function is not meant for Non-OPERA PMS or other
OXI-HUB interfaces.
CENTRAL SALES [CENTRAL_SALES] |
Enables the ability to create a Central Sales Hub where sales agents can manage central sales activities, manage sales accounts and create central sales leads to send to selected properties. |
CLOUD HUB INTEGRATION [ACTIVATE_PMS_INTEGRATION] |
Activates Cloud Hub Integration functionality by auto-creating
OXI-OPERA central interface configurations for the property.
CLOUD HUB INTEGRATION FOR ALL CENTRAL PROPERTIES [ACTIVATE_PMS_INTEGRATION_GLOBAL] |
Activates Cloud Hub Integration functionality by auto-creating OXI-OPERA central interface configurations for all properties in the chain. Note:
FILE ATTACHMENTS [ATTACHMENTS] |
Enables the ability to attach files (<10MB) to Profiles, Reservations, Blocks and Activities.
LEGACY OWS INTEGRATION [OWS_INTEGRATION] |
Activates Legacy OPERA Web Services (SOAP) Integration. |
MULTI LANGUAGE [GUEST_LANGUAGE] |
Enables the ability to add localized code descriptions for generating localized stationery. This function also actives alternate name functionality which allows properties to record guest names in the national character set for searching and output on guest stationery. |
OWNER [OWNER] |
Provides the ability to define and associate a sales owner code for each account (company/agent) profile and business block. The owner code can be referenced for filter criteria within reporting and searching within the application. (Enabled on activation of OPERA Cloud Sales & Event Management Essentials, Standard or Premium subscription). |
SCHEDULED REPORTS [REPORT_SCHEDULER] |
Activates Scheduled Reports Functionality. |
TEXT MESSAGE HANDLING [SMS_CONFIRMATIONS] |
Activates integration to SMS service providers for SMS text message delivery of confirmations, guest messages and queue room ready notifications to guests plus queue rush rooms alerts to housekeeping room attendants. Requires a subscription with local SMS service provider that supports email-to-sms or HTTP POST. |
TRACK IT [TRACK_IT] |
Track-It enables the management of tasks for the delivery and collection of guest luggage, vehicles, parcels, and other items which need to be tracked. Track-It also supports tracking of lost and found items. Track-It functionality is also available on a smartphone via the OPERA Cloud /mobile web application. |
DEFAULT PARCEL LOCATION [DEFAULT_PARCEL_LOCATION] |
Specifies the default location for Parcel type. |
DEFAULT PARCEL ACTION [DEFAULT_PARCEL_ACTION] |
Specifies the default action for Parcel type. |
DEFAULT PARCEL TYPE [DEFAULT_PARCEL_TYPE] |
Specifies the default type for Parcel type. |
DEFAULT VALET LOCATION [DEFAULT_VALET_LOCATION] |
Specifies the default location for Valet type. |
DEFAULT VALET ACTION [DEFAULT_VALET_ACTION] |
Specifies the default action for Valet type. |
DEFAULT VALET TYPE [DEFAULT_VALET_TYPE] |
Specifies the default type for Valet type. |
DEFAULT BAGGAGE LOCATION [DEFAULT_BAGGAGE_LOCATION] |
Specifies the default location for Baggage type. |
DEFAULT BAGGAGE ACTION [DEFAULT_BAGGAGE_ACTION] |
Specifies the default action for Baggage type. |
DEFAULT BAGGAGE TYPE [DEFAULT_BAGGAGE_TYPE] |
Specifies the default type for Baggage type. |
DEFAULT LOST LOCATION [DEFAULT_LOST_LOCATION] |
Specifies the default location for Lost type. |
DEFAULT LOST ACTION [DEFAULT_LOST_ACTION] |
Specifies the default action for Lost type. |
DEFAULT LOST TYPE [DEFAULT_LOST_TYPE] |
Specifies the default type for Lost type. |
Table 12-42 OPERA Controls — General Parameters
| PARAMETER | SETTING | DESCRIPTION |
ACCESS EXCLUSION [ACCESS_EXCLUSION] |
Enables access exclusion for the block. When a block access exclusion is configured for a business block, specific central reservation offices (CROs) cannot edit the block (i.e., add a new reservation or modify an existing reservation in the block; cancel a reservation in the block, or both). | |
ACTIVATE TEMPLATE TASKS ON ALL DEPENDENT PROPERTY ROLES [TEMPLATE_TASK_ACTIVATION_ON_PROPERTY_ROLES] |
Activates newly selected or deselected template tasks for all dependent property roles. |
DEVICE SELECTION FOR CHANGES LOG TRACKING [DEVICE_SELECTION_FOR_CHANGES_LOG_TRACKING] |
Enables display of device (client workstation) selection during user login for user activity tracking in the changes log. (Available with South Korea Country mode). |
ENABLE WATERMARK FOR REPORTS [REPORT_WATERMARK] |
Enables adding a watermark to all reports created in PDF format. |
CONFIGURE WATERMARK SETTINGS [REPORT_WATERMARK_MODE] |
Specifies the watermark settings to be applied to all reports in all properties where watermark functionality is active. This setting can be overridden by customizing watermarks on the report group or individual report level. |
FLEXIBLE DYNAMIC FIELDS [FLEXIBLE_DYNAMIC_FIELDS] |
Enables the ability to configure Flexible Dynamic Fields for use on Profiles. |
GUIDED LEARNING [GUIDED_LEARNING] |
Enables in-application guided learning. |
INFORMATION COLLECTION [INFORMATION_COLLECTION] |
Activate Information Collection functionality to allow for the collection of information at specific locations in OPERA Cloud. This includes the ability to configure which type of information collection functionality is active in the property. |
| DEFAULT METHOD FOR FOLIO DESTINATION[DEFAULT_METHOD_FOLIO_DESTINATION] |
Select the method which can be used as the default on the Folio Destination window for
which the instruction to print and/or email will be included in the universal payload.
DEFAULT EMAIL TYPE FOR FOLIO DESTINATION [FOLIO_DESTINATION_EMAIL_TYPE] |
Select the email type that will be set as the default in the Folio Destination window when New Email is selected and you enter an email address. |
INFORMATION COLLECTION METHODS [INFORMATION_COLLECTION_METHODS] |
Select the method(s) which will be used for Information Collection functionality.
PAYEE COUNTRY VAT NUMBER VALIDATION [PAYEE_COUNTRY_VAT_VALIDATION] |
Country from the payee profile primary address used for validation with Information Collection Methods VAT_NO_ID_TYPE and VAT_NO_TAX_ID. |
PROFILE ID TYPES FOR VAT NUMBER VALIDATION [PROFILE_ID_VAT_VALIDATION] |
Profile ID types used for validation with Information Collection Method VAT_NO_ID_TYPE. |
PROFILE TYPE FOR VAT NUMBER VALIDATION USING ID TYPE [PROFILE_VAT_VALIDATION_ID_TYPE] |
Payee profile type used for validation with Information Collection Method VAT_NO_ID_TYPE |
THRESHOLD AMOUNT FOR VAT NUMBER VALIDATION [THRESHOLD_AMT_VAT_VALIDATION] |
Payee profile type used for validation with Information Collection Method VAT_NO_TAX_ID. |
PROFILE TYPE FOR VAT NUMBER VALIDATION USING TAX ID [PROFILE_VAT_VALIDATION_TAX_ID] |
The threshold amount (net amount) to be reached for validation with Information Collection Methods VAT_NO_ID_TYPE and VAT_NO_TAX_ID. |
PAYEE COUNTRY FOR PAN NUMBER VALIDATION USING TAX ID 2 [PAYEE_COUNTRY_PAN_VALIDATION] |
Country from the payee profile primary address used for validation with Information Collection Method IN_PAN_VALIDATION. |
THRESHOLD AMOUNT (CASH) FOR PAN NUMBER VALIDATION USING TAX ID 2 [THRESHOLD_AMT_PAN_VALIDATION] |
The Cash transaction threshold amount for validation with Information Collection Method IN_PAN_VALIDATION. |
TRANSACTION CODES (CASH) FOR PAN NUMBER VALIDATION USING TAX ID 2 [CASH_TRANSACTION_CODE_PAN_VALIDATION] |
Cash transaction codes used for validation with Information Collection Method IN_PAN_VALIDATION. |
INTERFACE USER CLIENT IP AUTHORIZATION [INTERFACE_USER_IPS_VALIDATION] |
Disable or enable Client IP Address Authorization for Interface Users. |
MULTI PROPERTY [MULTI_PROPERTY] |
Activates template configuration and/or property-to-property copying of configuration. |
NUMERIC KEYBOARD FOR ROOM NUMBER [DEVICE_NUMERIC_KEYBOARD] |
Activates the mobile device keyboard to default to the numeric keyboard on selection of the Room Number field. |
PROPERTY BROCHURE [PROPERTY_BROCHURE] |
The Property Brochure is a resource that central sales, reservations, and on-property staff can use to obtain detailed information about services, facilities, accommodation at your property, and details on transportation options and local attractions in surrounding areas of your property. The Property Brochure can include high-quality photographs of your property accommodations and facilities and information on popular local attractions, dining and retail, local airports, transportation services, and other facilities. |
PROPERTY ROLES WITHOUT TEMPLATE [PROPERTY_ROLES_WITHOUT_TEMPLATE] |
Enables you to create property roles and assign tasks to the roles without needing to copy roles from template. |
RESTRICT CREDIT CARD MANUAL ENTRY [RESTRICT_CC_MANUAL_ENTRY] |
Prohibits manual inputting of credit card details in payment windows. |
SITE PLAN [SITE_PLAN] |
The Site Plan is available to display images of the property, facilities, amenities or other subject matter such as diagrams that are useful to staff. |
STORE IP ADDRESS IN CHANGES LOG [STORE_IP_ADDRESS_USER_ACTIVITY_LOG] |
When active the IP Address will be displayed in the Changes Log. |
VIEW RECENTLY USED RECORDS [RECENT_USED_RECORDS_MENU] |
Enables the View Recently Viewed Records list within the I Want To menu for Profile, Reservation, Event, Sales Activities and Block search screens. |
Table 12-43 OPERA Controls — General Settings
BACKGROUND [OPERA9_BACKGROUND] |
The color of the strip displayed at the top of the application. |
CENTRAL CURRENCY CODE [CENTRAL_CURRENCY_CODE] |
Defines the currency code used for Membership Calculation Rules and Redemption when applying exchange rates to Membership revenue and/or for viewing estimated rates in the Reservation Sales Screen availability in the preferred currency. |
CUSTOM TRANSLATION TYPE [CUSTOM_TRANSLATION_TYPE] |
Specifies the chain specific custom translation. |
DEFAULT SEARCH MODE [DEFAULT_SEARCH_MODE] |
Specifies the default search type used in Manage Profiles, Blocks, and Reservations. |
GAMING ID [GAMING_ID] |
Determines where the Gaming ID is stored. |
GOVERNMENT ID [GOVERNMENT_ID] |
The government identification associated with the property. |
IDLE SESSION TIMEOUT [IDLE_SESSION_TIMEOUT] |
Sets the idle session timeout period, in minutes, after which inactive user sessions
are automatically terminated.
Note: Setting the idle session timeout above 15 minutes may impact your PCI DSS compliance obligations. PCI DSS Requirement 8.2.8 requires re-authentication after 15 minutes of idle time for applicable user sessions. Consult your Qualified Security Assessor before increasing this value. |
PROPERTY TAX ID [PROPERTY_TAX_ID] |
Specifies the tax identification number for the property. |
PROXY CREDENTIALS [PROXY_CREDENTIALS] |
N/A |
PROXY SERVER [PROXY_SERVER] |
N/A |
PROXY SERVER BYPASS [PROXY_SERVER_BYPASS] |
N/A |
STATIONERY SUBSTITUTION LANGUAGE [STATIONERY_FALLBACK_LANGUAGE] |
Select a substitution (fallback) language to use when a stationery template is not configured for a specific profile language. Applicable when the Multi Language OPERA Control is active. Note: |
TENANT ID [TENANT_ID] |
Tenant ID for launching Reporting and Analytics from Reports menu. |
WEEKEND DAYS [WEEKEND_DAYS] |
Specifies the weekend days. |
Parent topic: About OPERA Controls
