Profiles Parameters and Settings
Table 32-6 Profiles Group parameters and settings.
| Parameter Name | Parameter Value | Direction of transmission where parameter applies.Parameter Description | Recommended Setting |
ACCEPT ANONYMIZATION UPDATE |
Y/N/YR |
-> Direction: Data from external system to OPERA Cloud. This parameter determines whether to anonymize the OPERA Cloud profile when the update profile message is received with anonymize flag and the Profile Information Protection functionality is active. - If set to YR (Yes and Return), the OPERA Cloud profile will be anonymized and a snapshot of the profile will be sent back to the calling system after it has been anonymized in OPERA Cloud. The calling system must be subscribed to the UPDATE PROFILE business event to receive the profile update. - If set to Y the OPERA Cloud profile will be anonymized. A profile update will NOT be sent back to the calling system after the profile is anonymized. - If set to N the OPERA Cloud profile will NOT be anonymized. |
Set accordingly. |
ACCEPT CENTRAL MERGE |
ALL Select one or more profile types |
-> Direction: Data from external system to OPERA Cloud. This parameter determines whether to merge corresponding OPERA Cloud profiles when the received PROFILE message contains MergedIDs. - If this parameter is set to 'ALL' or one or more profile types, OXI will attempt to merge while processing messages of the specified profile types and will update the merged profile with the information received in the message. - If this parameter is not set to any value, OXI will ignore MergedIDs in the message and will update one matching profile with the information received in the message. |
Set accordingly. |
ACCEPT PRIVACY UPDATE |
Y/N |
-> Direction: External system to OPERA Cloud. This parameter determines whether to update the privacy options in OPERA Cloud profile when the profile message is received. - If this parameter is set to 'Y' then privacy fields in OPERA Cloud profile will be updated. - If this parameter is set to 'N' then privacy fields in OPERA Cloud profile will NOT be updated. |
Set accordingly. |
ADDRESS/COMMUNICATION HANDLING |
ENABLED/DISABLED |
Direction: This parameter controls how the phones/addresses received from the external
system update the corresponding data in OPERA. If Enabled, data received will append to the
existing values in OPERA for the same type. If no data is received, the existing values in
OPERA will remain unchanged for the same type. If Disabled, OPERA values will be replaced
with the data received (full overlay).
Note: The Phone and Address Overwritten control is being deprecated and replaced by a new control, which will now be the primary method of handling this functionality. |
Set accordingly. |
CHANGE TO PROFILE GENERATES |
PROFILE RESERVATIONS |
- > Direction: Data from OPERA Cloud to external system. This parameter specifies how OXI will use the following event: a change to a profile occurs in OPERA Cloud and a Profile business event is generated. When this parameter is set to 'Profile': if the external system has a profile concept and can apply the changes to only the profile record. When this parameter is set to 'Reservations': if the external system has a concept of Guest Name Record (GNR), where the guest information is stored with the reservation record. In this case, OXI will search all active reservations linked to that profile and send reservation updates for these records. |
The default for this parameter is Profile. |
CORP EXT CRS OVER |
Y/N |
-> Direction: Data from external system to OPERA Cloud. This parameter determines whether a company profile shall be overwritten from the external system or not. This may be desirable if the external system has more accurate company data than the OPERA Cloud database. Set to Y and the external system profile details for company profiles will overwrite the existing OPERA Cloud profile. Set to N and the OPERA Cloud details will remain unchanged. Even if this parameter is set to Y you can manipulate how data is being overwritten with the use of profile parameters INTEREST EXT CRS OVER, NEGRATES EXT CRS OVER, PHONE/ADDR EXT CRS OVER, PREF EXT CRS OVER, PROFCOMMENTS EXT CRS OVER. |
Set to Y if external system shall be allowed to update. |
DISCARD DUPLICATE MEMBERSHIPS |
Y/N |
-> Direction: Data from external system to OPERA Cloud. If set to Y, discard received memberships if they already exist in another OPERA Cloud profile and issue warning. If set to N, profile will be created without checking if the received memberships already exist in another OPERA Cloud profile. |
Set accordingly. |
PROCESS INBOUND DOCUMENTS |
Global, determines if documents are processed. |
DOCUMENT TYPES TO EXCHANGE |
ALL NONE Configured Document Types |
-> Direction: Data from OPERA Cloud to External System only. Only Global, and not resort specific, documents will be exchanged based on the parameter setting. Select 'ALL' to exchange all Document Types. Select 'NONE' to exchange no Document Types. Select Document Types in any combination, to restrict the Document Type exchange to the selected values. If the parameter value is not set, as is (backward compatible), with OPERA Cloud interfaces ALL Document Types will get exchanged; but with External Interfaces only 'PASSPORT' Document type will get exchanged. |
Select the Document Types to Exchange |
GROUP EXT CRS OVER |
Y/N |
-> Direction: Data from external system to OPERA Cloud. This parameter determines whether a group profile shall be overwritten from the external system or not. This may be desirable if the external system sends many details in the group profile while the OPERA Cloud database only has the name. Set to Y and the external system profile details for group profiles will overwrite the existing OPERA Cloud profile. Set to N and the OPERA Cloud details will remain unchanged. Even if this parameter is set to Y you can manipulate how data is being overwritten with the use of profile parameters INTEREST EXT CRS OVER, NEGRATES EXT CRS OVER, PHONE/ADDR EXT CRS OVER, PREF EXT CRS OVER, PROFCOMMENTS EXT CRS OVER. |
HANDLE RESORT AR NUMBERS |
FULLOVERLAY IGNORE MERGE |
-> Direction: Data from external system to OPERA Cloud This parameter determines how to handle the incoming resort AR numbers in the ResortArs collection. When set to FULLOVERLAY, all received AR Numbers for the resort will get inserted or updated, for new AR numbers OXI will copy the primary address of the profile as AR address. Existing AR numbers will only get deleted if OPERA Cloud parameter 'ACCOUNTS_RECEIVABLES' is set to 'N' When set to MERGE, incoming AR numbers will Only get merged with existing Resort AR Numbers. When set to IGNORE, incoming AR numbers will be ignored. |
HANDLE RESORT PAYMENT METHOD |
-> Direction: Data from external system to OPERA Cloud This parameter determines how to handle the incoming Profile Resort Payment Method. When set to FULLOVERLAY, existing Profile Resort Payment Method will get overwritten with the incoming value. When set to UPDATE, update only if existing Profile Resort Payment Method is null. When set to IGNORE, incoming Profile Resort Payment Method will be ignored. |
IND EXT CRS OVER |
Y/N |
-> Direction: Data from external system to OPERA Cloud. This parameter determines whether an individual profile shall be overwritten from the external system or not. This may be desirable if the external system has more accurate guest data than the OPERA Cloud database. Set to Y and the external system profile details for individual profiles will overwrite the existing OPERA Cloud profile. Set to N and the OPERA Cloud details will remain unchanged. Even if this parameter is set to Y you can manipulate how data is being overwritten with the use of profile parameters INTEREST EXT CRS OVER, NEGRATES EXT CRS OVER, PHONE/ADDR EXT CRS OVER, PREF EXT CRS OVER, PROFCOMMENTS EXT CRS OVER. |
INTEREST EXT CRS OVER |
Y/N |
-> Direction: Data from external system to OPERA Cloud. This parameter will come into effect if you allow profiles to be overwritten in general. This means at least one of your parameters IND EXT CRS OVER, CORP EXT CRS OVER, TA EXT CRS OVER, SOURCE EXT CRS OVER, or GROUP EXT CRS OVER have to be set to Y. The functionality of this parameter is further determined by the mode of your interface. If it works with Delta Changes set to Yes (Interface Configuration > Edit Interface), the external system can send profile changes only and does not need to send the full profile every time a small change to a profile occurs. OXI will then only update the changed data and not touch the additional data that was found in the OPERA Cloud profile. This also means that the external system needs to indicate intended deletions clearly with deletion indicators in the message. Sending simply blanks will not lead to data deletion if OXI works in Delta mode. The deletion indicators can be configured in interface configuration > edit interface. If your interface is set to Delta changes No, OXI expects a full overlay of all profile data in every profile message, even if the external system only changes very little of the entire profile. Here is how the parameter works: If your interface is setup as Delta Changes = Y and no interests are sent by external system in the profile message, this parameter is ignored and the existing OPERA Cloud profile interests remain untouched. Otherwise the following parameter rules apply: If Y, interests sent by external system will overwrite existing OPERA Cloud profile interests. If N, interests sent by the external system will be appended to existing OPERA Cloud profile interests. |
Determine whether values shall overwrite or append and select your setting accordingly. |
MAX PROFILE MATCHES |
Y/N |
-> Direction: External System to OPERA Cloud only. This setting impacts the search depth for profiles meeting matching criteria, prior to establishing weighted points: - A lower setting (i.e. 10) will favor execution speed, while correctly matching the vast majority of profiles. - A higher setting (i.e. 100) will favor even very distinct differentiation, while providing very good execution speed. - A setting of 1000 can have a negative impact on performance, when reservations are received with limited profile information. - Leave blank, if you want OXI to always find and weigh all possible matches. If the value is left blank and you have limited information in the message (i.e. John Smith in New York) and several thousand potential duplicates can be found in the database, processing these reservations may take several minutes. During this time, the OXI Download processor will go into WAITING status and users will be prompted with a warning about the state of the interface. |
Set accordingly. |
| Match Criteria | Direction: Data from external system to OPERA. Values set for this parameter will designate which Match Criteria are validated when profiles are sent from external systems to OPERA. A = last name, city B = last name, first name, city C = last name, partial address 1 D = passport E = last name, phone F = last name, legal company G = company name, city H = company name, partial address 1 I = xlast, keyword J = last, keyword K = company name, credit card number L = last, first, address 1 N = match only on internal id for profiles having AR number for same properties Q = xcompany, address 1 R = xcompany, phone S = matched on index for company name and address: INDEX_NAME (only consonants) and ADDRESS1 (first 7 characters) U = matched on partial company name and address: COMPANY (first 5 and last 5 characters) and ADDRESS1 (first 7 characters) T = matched on partial company name and address: COMPANY (first 5, 10-15, and last 5 characters) and ADDRESS1 (first 7 characters) W = matched on partial index of company name and address: COMPANY (first 5 and last 5 characters) and ADDRESS1 (first 7 characters) 2 = xcompany, city 3 = XLAST and XADDRESS (First 3 Double Byte Characters of the Address) 4 = membership no, last name. | ||
| Multiple Matches | Direction: Data from external system to OPERA. When Enabled and a match is found on property ID, the interface will look further into the database for other potential matches based upon the selected criteria. When Disabled a match on profile ID will lead to a direct merge prompt for that profile. | ||
NEGRATES EXT CRS OVER |
Y/N |
-> Direction: Data from external system to OPERA Cloud. This parameter will come into effect if you allow profiles to be overwritten in general. This means at least one of your parameters IND EXT CRS OVER, CORP EXT CRS OVER, TA EXT CRS OVER, SOURCE EXT CRS OVER, or GROUP EXT CRS OVER have to be set to Y. The functionality of this parameter is further determined by the mode of your interface. If it works with Delta changes set to Yes, (Interface Configuration > Edit Interface), the external system can send profile changes only and does not need to send the full profile every time a small change to a profile occurs. OXI will then only update the changed data and not touch the additional data that was found in the OPERA Cloud profile. This also means that the external system needs to indicate intended deletions clearly with deletion indicators in the message. Sending simply blanks will not lead to data deletion if OXI works in Delta mode. The deletion indicators can be configured in interface configuration > edit interface. If your interface is set to Delta changes = No, OXI expects a full overlay of all profile data in every profile message, even if the external system only changes very little of the entire profile. Here is how the parameter works: If your interface is setup as Delta Changes = Y and no negotiated rates are sent by the external system in the profile message, this parameter is ignored and the existing OPERA Cloud profile negotiated rates remain untouched. Otherwise the following parameter rules apply: If Y, negotiated rates sent by external system will overwrite existing OPERA Cloud profile negotiated rates. If N, negotiated rates sent by the external system will be appended to existing OPERA Cloud profile negotiated rates. |
PHONE EXTENSION SYS OVER |
Determines whether to send the phone extension. |
PHONE/ADDR EXT CRS OVER |
(see description) |
-> Direction: Data from external system to OPERA Cloud. This parameter determines how the phone/addresses received from the external system update the phone/addresses in OPERA Cloud. This parameter will supersede the Delta setting of the interface. A = If received, replace OPERA Cloud values with the received values. If not received, remove the values from OPERA Cloud. B = If received, replace OPERA Cloud values with the received values. If not received, do not remove the values from OPERA Cloud. C = If received, merge the received values with OPERA Cloud values. If not received, remove the values from OPERA Cloud. D = If received, merge the received values with OPERA Cloud values. If not received, do not remove the values from OPERA Cloud. N = Ignore the phone/addresses received. Do not touch the values in OPERA Cloud. |
PREF EXT CRS OVER |
Y/N |
-> Direction: Data from external system to OPERA Cloud. This parameter will come into effect if you allow profiles to be overwritten in general. This means at least one of your parameters IND EXT CRS OVER, CORP EXT CRS OVER, TA EXT CRS OVER, SOURCE EXT CRS OVER, or GROUP EXT CRS OVER have to be set to Y. The functionality of this parameter is further determined by the mode of your interface. If it works with Delta changes set to Yes, (Interface Configuration > Edit Interface), the external system can send profile changes only and does not need to send the full profile every time a small change to a profile occurs. OXI will then only update the changed data and not touch the additional data that was found in the OPERA Cloud profile. This also means that the external system needs to indicate intended deletions clearly with deletion indicators in the message. Sending simply blanks will not lead to data deletion if OXI works in Delta mode. The deletion indicators can be configured in (Interface Configuration > Edit Interface.) If your interface is set to Delta changes no, OXI expects a full overlay of all profile data in every profile message, even if the external system only changes very little of the entire profile. Here is how the parameter works: If your interface is setup as Delta Changes = Y and no preferences are sent by the external system in the profile message, this parameter is ignored and the existing OPERA Cloud profile preferences remain untouched. Otherwise the following parameter rules apply: If Y, preferences sent by external system will overwrite existing OPERA Cloud profile preferences. If N, preferences sent by the external system will be appended to existing OPERA Cloud profile preferences. |
PRIMARY MEMBERSHIP UPDATES |
ON/OFF |
-> Direction: Data from external system to OPERA. This parameter defines if the Membership data from the External system will be accepted for the Primary Members Profile. When turned ON the external system primary member profile details for Guest/Contact profiles will overwrite the existing OPERA profile membership details. Set to OFF and the OPERA Cloud details will remain unchanged. (If set to ON, functionality for Suspended profiles works as it does today). |
default ON |
Y/N |
->Direction: Data from external system to OPERA. This parameter defines if the Membership data from the External system will be accepted for the Primary Members Profile through Cloud Hub. When turned ON the external system primary member profile details for Guest/Contact profiles will overwrite the existing OPERA profile membership details. Set to OFF and the OPERA Cloud details will remain unchanged. (If set to ON, functionality for Suspended profiles works as it does today). | Set accordingly. |
PROFILE CREATION |
Y/N |
-> Direction: Data from external system to OPERA Cloud If you do not have any reason for not creating a new profile in case a match could not be found, this parameter should always be set to either Y or a comma separated combination of the alphabets A, B, C, D, E AND F. Each alphabet stands for specific profile selection: A- Guest B- Corporate C- Group D- Travel Agent E- Source F- Contact For all interfaces that transmit reservations and blocks, this parameter has to be set to either Y or the above alphabet combination and a new profile will be created in case no profile match and merge with an existing OPERA Cloud profile is possible. The reason that a profile fails the match can be that the profile does not make the entry match criteria or that it fails in the weighing point match criteria. Set this parameter to N if you do not transmit blocks and reservations in your interface, and no new profile will be created in case profile match fails. |
Set Accordingly. |
PROFILE MATCHING |
Y/N |
-> Direction: Data from external system to OPERA Cloud Set to Y in order to use the OXI Profile Matching routine with entry match criteria and weighing point match criteria. In case you do not require profile matching, for example, if OPERA Cloud and the external system share their internal profile numbers both ways and always have an ideal match, you can select to set this parameter to N. The OXI Profile Matching routine will then be ignored. |
Set Accordingly. |
PROFCOMMENTS EXT CRS OVER |
Y/N |
-> Direction: Data from external system to OPERA Cloud. This parameter will come into effect if you allow profiles to be overwritten in general. This means at least one of your parameters IND EXT CRS OVER, CORP EXT CRS OVER, TA EXT CRS OVER, SOURCE EXT CRS OVER, or GROUP EXT CRS OVER have to be set to Y. The functionality of this parameter is further determined by the mode of your interface. If it works with delta changes set to Yes (interface configuration > edit interface), the external system can send profile changes only and does not need to send the full profile every time a small change to a profile occurs. OXI will then only update the changed data and not touch the additional data that was found in the OPERA Cloud profile. This also means that the external system needs to indicate intended deletions clearly with deletion indicators in the message. Sending simply blanks will not lead to data deletion if OXI works in delta mode. The deletion indicators can be configured in (Interface Configuration > Edit Interface.) If your interface is set to delta changes No, OXI expects a full overlay of all profile data in every profile message, even if the external system only changes very little of the entire profile. Here is how the parameter works: If your interface is setup as Delta Changes = Y and no comments are sent by the external system in the profile message, this parameter is ignored and the existing OPERA Cloud profile comments remain untouched. Otherwise the following parameter rules apply: If Y, comments sent by external system will overwrite existing OPERA Cloud profile comments. If N, comments sent by the external system will only overwrite OPERA Cloud profile comments where the update_user=interface ID, and the ones that were last changed by the OPERA Cloud user remain untouched. |
RELATIONSHIP |
None All Global Send Conversion Only |
-> Direction: Data from external system to OPERA Cloud and from OPERA Cloud to external system. This parameter manages the transfer of relationship associations between OPERA Cloud and External Systems. This parameter consists of 4 distinct settings (All, None, Global, Send with Conversion only). This parameter is valid only for Profile Schema v3 and above. None - When active, no relationship data will be sent to or received from External system. All - Any update to the relationship will be updated in the receiving system regardless of local or global designation. Global - Only relationship indicated as global will be exchanged. Any local relationships will not be exchanged or updated. Send with Conversion Only - Only relationships with active conversions will be exchanged between systems. |
Setting is based on the use of profile relationships; select accordingly. |
RELATIONSHIPS INCOMING |
ALL GLOBAL NONE |
-> Direction: External System to OPERA Cloud only. This parameter manages the transfer of relationship associations between OPERA Cloud and External.
None - When active, no relationship data will be sent or received from External system. All - Any update to the relationship will be updated in the receiving system regardless of local or global designation. Global - Only relationship indicated as global will be exchanged. Any local relationships will not be exchanged or updated. |
Set Accordingly. |
RELATIONSHIPS OUTGOING |
ALL GLOBAL NONE |
-> Direction: OPERA Cloud to External System only. This parameter manages the transfer of relationship associations between OPERA Cloud and External.
Set Accordingly. |
REPLACE MEMBERSHIP CARD NUMBER |
Y/N |
-> Direction: Data from external system to OPERA Cloud If set to 'Y', update the card number of the existing membership with same type. If set to 'N', inactivate current membership of same type and create a new membership with the received membership number. |
SOURCE EXT CRS OVER |
Y/N |
-> Direction: Data from external system to OPERA Cloud. This parameter determines whether a source profile shall be overwritten from the external system or not. This may be desirable if the external system has more accurate data on the source or wholesaler than the OPERA Cloud database. Set to Y and the external system profile details for source profiles will overwrite the existing OPERA Cloud profile. Set to N and the OPERA Cloud details will remain unchanged. Even if this parameter is set to Y you can manipulate how data is being overwritten with the use of profile parameters INTEREST EXT CRS OVER, NEGRATES EXT CRS OVER, PHONE/ADDR EXT CRS OVER, PREF EXT CRS OVER, PROFCOMMENTS EXT CRS OVER. |
TA EXT CRS OVER |
Y/N |
-> Direction: Data from external system to OPERA Cloud. This parameter determines whether a travel agent profile shall be overwritten from the external system or not. This may be desirable if the external system has more accurate agent data than the OPERA Cloud database. Set to Y and the external system profile details for agent profiles will overwrite the existing OPERA Cloud profile. Set to N and the OPERA Cloud details will remain unchanged. Even if this parameter is set to Y you can manipulate how data is being overwritten with the use of profile parameters INTEREST EXT CRS OVER, NEGRATES EXT CRS OVER, PHONE/ADDR EXT CRS OVER, PREF EXT CRS OVER, PROFCOMMENTS EXT CRS OVER. |
UPDATE SALUTATION |
Y/N |
-> Direction: Data from external system to OPERA Cloud. When this parameter is set to Y, OXI will update the salutation of a profile based on the profile's title handling, each time a PROFILE message is received. When this parameter set to N, OXI will insert salutation when inserting a new profile, but will then not update this salutation, to allow users to maintain custom salutations in OPERA Cloud. |
Default is N. Set accordingly. |
VIP EXT SYS OVER |
Y/N |
->Direction: Data from external system to OPERA. This parameter will come into effect if you allow profiles to be overwritten in general. This means at least one of the parameters IND EXT SYS OVER, CORP EXT SYS OVER, TA EXT SYS OVER, SOURCE EXT SYS OVER, or GROUP EXT SYS OVER have to be set to 'Y'. The functionality of this parameter is further determined by the 'mode' of your interface. This parameter determines whether to update the VIP status in profile when the profile message is received via OXI Interface. - If this parameter is set to 'Y' then VIP field in OPERA profile will be updated. - If this parameter is set to 'N' then VIP field in OPERA profile will not be updated. |
Set accordingly. |
OXI_PROFILES: PROCESS INBOUND DOCUMENTS |
Y/N |
-> Direction: Data from External System to OPERA Cloud only. Only Global, and not resort specific, documents will be processed based on the parameter setting. Select 'Y' to process all received Document Types. Select 'N' to ignore all received Document Types. |
OXI_PROFILE: PHONE EXTENSION SYS OVER |
Y/N |
-> Direction: Data from External system to OPERA Cloud This parameter determines whether to send phone extension .
Parent topic: Interface Controls
