Activating/Issuing Prepaid Card
You can activate or issue transaction for a prepaid card or a stored value card (SVC). This option allows you to activate or issue the card and add a value to the card as per the amount given.
You can activate or issue a prepaid card either from the Reservation Information or Billing screen.
Only you can activate or issue a prepaid card once the guest has checked in successfully.-
From the OPERA Cloud menu, select Bookings, select Reservations, and then click Manage Reservation.
Search for and open the reservation.
Click Prepaid Card details link.
Or
Click I Want To… and then select Billing.
Enter your credentials if requested.-
Select the Cashier ID.
Enter PIN to proceed.
Click Login.
The Billing Information screen appears.
Click Issue Card.
The Prepaid Cards screen appears. Complete the following:-
Prepaid Card Interface: Select the prepaid card interface from the list.
Card Number: Enter the gift card number.
Name/First Name: Default the primary profile linked to the reservation.
Amount: Enter the issue amount.
Payment Options:
Post Amount to Room: Select the post issue amount to guest folio (reservation account).
This option is available only once the guest is checked in.Or
Make Payment: Select the payment needs to be provided at this time. This option requires payment for the gift card at the time the card is issued.
Method: Select a payment method from the list.
You can enter credit card details manually through OPERA PAY. See Credit Card Guarantee through the OPERA Cloud Application (Manual Entry – OPERA Pay)for more information.
Card Number: Enter credit card number.
Expiration: Enter credit card expiry date.
Click Issue Card.
