Pre-Authorization Rules
OPERA Cloud provides support for automated Pre-Authorization Rules. You can set the rules as follows:
A standard rule across the OPERA Cloud Property.
OR
A customized pre-authorization rule based on Room Type, Room Class, Rate Code, Rate Category, Reservation Type and Source Code.
These rules are used upon check-in and control the pre-authorized amount against a guest card upon arrival.
Refer to About Credit Card Authorization Rules for details.
Parent topic: Review Standard Operating Procedures
