Configuring Advanced Deposit Handling
You can configure Advanced Deposit Handling control setting
to blank, 0, 1, 2 for Pay by Link. If the control is not set, you
cannot send the payment link to the guest.
The Pay by link option is not available when Advance Deposit handling OPERA control setting is set to 3 to 15. If you are trying to set the Advance Deposit handling value between 3 and 15 when Pay by Link control is active, the system displays an error message saying 'Pay By Link is active'.
Log in to OPERA Cloud using the URL provided.
Enter your User Name and Password in the fields provided.
From the Administration menu, select Enterprise, then select OPERA Controls.
Enter or search for the property.
OPERA Control groups are listed down the left side panel, select the Cashiering group.
Click the edit icon in the Advanced Deposit Handling setting. Click the Search icon in the Configure Setting screen.
Click Select to select the Advanced Deposit Handling.
