Creating a Group
Log in to OPERA Cloud Identity Management using the URL provided.
Enter your User Name and Password in the fields provided.
Select the Groups tab and click the Manage user groups to create a group.
The Groups Information screen appears.
Click Create Group (
) to create a CCCONF
or PPCONF group.
The Create Group screen appears.
Enter the Group name.
Enter the Group Description about the group.
Select or enter the Location manually. For example, Organization code (chain (SH) or property (349).
Click Create to create a group.
The Group profile screen appears.
Once the group profile is created, you can assign users to the group. See Assigning a User to CCCONF Group or Assigning a User to PPCONF Group for assigning users to the group.
