Server Hardware Recommendation
The following table represents the recommended hardware details of the Token proxy service and other related components for Self-Hosted Token Proxy services.
Table 4-1 Token Proxy Service Hardware Recommendations
| Hardware | Recommendation |
TPS Service Server |
CPU 2.6GHz with 2 cores; 16GB RAM;(HW Spec used in the lab: Intel(R) Xeon(R) CPU E5-2690 v4 @ 2.60GHz with 2 cores and 16 GB RAM and total Specint per node-48 (as per SPECint_rate2006)) |
Web Portal Server |
Database Server |
CPU 2.6GHz with 2 cores; 16GB RAM;(HW Spec used in the lab: Intel(R)Xeon(R) CPU E5-2690 v4 @2.60GHz 2.59GHz with 2 cores and 16 GB RAM and total Specint per node-48 (as per SPECint_rate2006)) |
Parent topic: Self-hosted on Multiple Machines/VM
