Creating the MW_HOME Variable
This section is not applicable if you want to deploy Token Proxy Service using Tomcat.If you do not have an MW_HOME variable and want to use the Token
Proxy Installer to deploy the WebLogic .WAR file and to create the
datasource on the machine you are running the installer on, cancel
the installation and create an environment variable to reflect your
WebLogic environment.
Open Windows System Properties, click the Advanced tab, and then click Environment Variables.
Click New in the System Variable section, and then enter MW_HOME in the Variable name field and path of the WebLogic installation in the Variable value field.
This will vary depending on your WebLogic installation path, but an example value might be :\Oracle\Middleware\Oracle_Home
Click OK to confirm, and then exit System Properties.
Re-run the installer after creating the MW_HOME Environment Variable.
Parent topic: Installing Token Proxy Service
