Logs
If something is not working as expected, you should be able to see more information on why by consulting the Cert Manager logs;
: \TokenProxy\TokenProxyCertManager\log
Logs will also need to be supplied in the event of any support request.
Parent topic: Certificates Request using Cert Manager
