Restoring Weblogic DemoIdentity Certificates
Make sure you have the details of your certificates, as these will need to be reinstated again after the update process has been completed.
Login to your WebLogic’s admin console.
Navigate to the Environment | Servers tab.
Select the AdminServer.
Navigate to the Keystores tab.
Select 'Lock and Edit' the configuration.
Select the 'Change' option and select the 'Demo Identity and Demo Trust' option from the list.
'Save' your changes, and 'Release Configuration'.
Restart the wls admin server.
Once the update has completed successfully restore your certificates using the Cert Manager in the normal way.
Parent topic: TPS DemoIdentity Upgrade
